Gryphon Diablo Integrated Amplifier Owners
Great stuff!! I am still working on the 800S to get it to work well for me...in many respect a tremendous headphone. The amp (EAR Yoshino HP4) is a stunning piece of work. Expecting the TA Ultra headphone cable several weeks.
Reactions: _Alchemist_
Thanks for your response,
Which one did you replace? just the 8A one?
Is it a big difference over the stock fuse? What difference did you notice?
Have you tried the QSA fuses?
I replaced the 6.3A one at the back of the amp.
Also replaced the ones of my Aqua LinQ and Formula DAC.
You get more transparency, wider soundstage and a more holographic.
Only tried SR Purple fuses so far and don't plan o trying any other brands.
Thank you - Did you pick slow or fast for the Diablo? And which direction worked best for you?
You need slow blow.
Direction is S at the back and R towards the front of the unit.
I'm currenty testing Gryphon 120 with Sonus Faber Electa Amator 1. It's running up against my Jadis da88s. The result:
I'm seriously thinking of doing a swap. Great amp.
Hi,
Can you please elaborate on the main diferences between the Jadis and the Gryphon?
Thank you.
I'm investigating integrated amplifiers to power my new Harbeth Monitor 30.2 Anniversary Editions.
Do we have any Diablo owners in the group? I'd appreciate your comments.
Edit: Specifically the Diablo 120.
Hi ,
I have a Gryphon 120 integrated amp
super 5 HLS XD harberth
Can anyone tell me or suggest which speaker cables are best to use also AEU/EBU interconnect ?
thx
