Using an integrated amp as power amp
MichaelC
3
61
Good morning, I want to test several preamps in my setup for the idea of further upgrade.
may I ask whether it is possible to bypass the preamp of my integrated amp (Nagra Classic Int) and connect an external preamp? Would really appreciate to bypass the internal preamp of the Nagra Classic Int. Could you explain what settings/connections would have to be done?
thx so much, greetings, Michael
I looked at the manual Michael and there is no clearly documented way to bypass the preamplifier/directly access the amplifier section of your Integrated. I would suggest contacting Nagra Technical Support directly to see if this can be done.
Kerry
Reactions: MichaelC
Thx for your advice. Happy Easter!
hi Michael, did you ever find a solution to be able to bypass the pre-amp in your Classic INT? I'm looking at a Classic INT now that I would only consider buying if I could bypass the preamp when so desired.
