About to buy MA-1 monos- how long do the tubes last and how easy are replacements to source?
tima
5,875
6,952
1,400
the Upper Midwest
Next week. I'm trying to understand what each 6SN7 position does, I think the two nearest tube dial are the most important re sound impact. I've emailed Ralph to clarify but didn't get a response yet.
I asked that same question of Ralph in 2006:
"The 2nd and 3rd 6SN7 from the edge of the chassis with the power supply cover are the most sensitive. They are in parallel, so for best effect both should be changed."
Here is the thread on 6SN7s:
Reactions: treitz3
Nuforce
175
98
95
47
Ah that's great, thanks so much
Phantom-Audio
335
383
195
Jakarta
www.phantom-audio.com
Phantom-Audio
335
383
195
Jakarta
The Nirvana by Atma-Sphere 120-150 watts per mono depending on tubes used.
ACHiPo
519
309
310
Pleasanton, CA
All the V1 tubes are paralleled so as to drive the top tube of the differential cascode circuit (V2) with greater ease. The biggest voltage drop is across V4 which is why you need a -GTA or -GTB (note; the Russian and Shuguang 6SN7s are marked 'GT' but are GTBs).
ACHiPo
519
309
310
Pleasanton, CA
nu Force,
just saw you’re getting the older chassis. There should be info in the manual online as to which position is V1, etc.
Nuforce
175
98
95
47
So v1a on the older rectangular units like mine is the tube on the edge where the power supply is?
So am I right in saying that positions v1a and v1b achieve the most benefit from uprated tubes?
I am going to buy a quad of psvane 181-Tii
Reactions: DetroitVinylRob
Nuforce
175
98
95
47
Actually Tima sorry I missed your post, so it is position v1b and v1c that yield the most benefit right ?
tima
5,875
6,952
1,400
the Upper Midwest
I don't translate the position names from prior style - just follow RKs instructions. The MA-1s I had were in the same rectangular shape as the ones you are getting. I had the Mk3.1. And fwiw, Ralph can upgrade your units to current spec without changing the chassis.
You might like my article at TAB about upgrading. Looking at the lead-in picture, count from the right. Iirc there was no restriction on the type of 6SN7 (GTA/GTB etc.) - at least I did not and had zero issues. Edit: I did not try the PSVANE tubes, but I did try the Chinese Shuguang - they were a bit on the warmish, rounding side of things. Imo the older Ken-Rad black glass, Sylvania, and RCA 6SN7s are the best.
Nuforce
175
98
95
47
I've read your article, l love it, so well written!
I'll need to ask RK to kindly pass his conversion diagrams to my local valve engineer. He may be willing. I'm in the UK and don't relish sending these amps overseas.
Nuforce
175
98
95
47
I don't understand. Why do you need conversion diagrams? What are you converting?
I mean upgrading to 3.3, I assume it requires rewiring etc?
Nuforce
175
98
95
47
i have another question re the MA-1, how important is it to keep the speaker cables short, given the OTL design?
I have the option to run them next to my magnepans, however I worry about excessive vibration in that location.
Is short cable length very important or a nice to have?
Atmasphere
2,381
1,872
1,760
St. Paul, MN
www.atma-sphere.com
Yes.
The vibration, especially with Maggies, is a non-issue. So run the shortest cables you can- we've often had owners back the speaker terminals of the amps to nearby the speaker terminals of the Maggies and just run short 8 inch jumpers, which can work quite well. If you have Maggies properly set up, there should be plenty of room behind the speakers to set the amps up.
Reactions: Nuforce
Nuforce
175
98
95
47
My amps have arrived!
I've left them on my rack for now.
ACHiPo
519
309
310
Pleasanton, CA
Nuforce
175
98
95
47
I'm slightly disappointed that the power meters don't illuminate...
What I am delighted about is bringing two Minnesota cousins together, Atma-sphere and Magnepan.
Should be a special match.
Nuforce
175
98
95
47
Thanks for the pictures. The amps need more air circulation. Those tubes throw off lots of heat.
Agreed, I'm moving them to the top of my rack. I don't want them next to my speakers, too fragile with my kids around
