Seems I miss every time lolDon't shoot! Digital is never done.
How soon until you have anti-virus software on your server?
Did you update already?
I held off Christoph… it can’t hurt to put it off for a few days just in caseDid you update already?
All smoothly?
Build 987 -- more cowbell!
SNL OMG… Life goes full circle. 20 years ago Walken projected that build 987 would completely Roon his career. 987 upgrade notes should say that its a fix for the reaper virus and generally aids with percussion. Should we take it as a omen and perform the ritual throw the Roons and see what it brings nextBuild 987 -- more cowbell!
Steve Z
I am also on build 988 and for what it’s worth, I’ve had zero issues with the last several updates. I’ve also not noticed any significant changes to sound quality - it’s been consistently good in my opinion.SNL OMG… Life goes full circle. 20 years ago Walken projected that build 987 would completely Roon his career. 987 upgrade notes should say that its a fix for the reaper virus and generally aids with percussion. Should we take it as a omen and perform the ritual throw the Roons and see what it brings next
Same here, just using squeezelite output engineUpdated and - not a darn bit of difference. Still sounds great feeding HQplayer!
Yep I did, (prefer Qobuz over Tidal) and works fine.Any of you tried the new "prefer(Qobuz)-over(Tidal)-feature" (or vice-versa) I was requesting over a year ago that they FINALLY implemented?
Are you saying there’s a ‘feature’ in Roon that simplifies comparing the same file on Qobuz vs Tidal? I have done it myself but only the old fashion way by clicking on versions and then selecting the other platform. Not that that process is super difficult but if there’s an easier way to do it, I’d love to try it!Any of you tried the new "prefer(Qobuz)-over(Tidal)-feature" (or vice-versa) I was requesting over a year ago that they FINALLY implemented?
I have to begin with Adam and Eve here:Are you saying there’s a ‘feature’ in Roon that simplifies comparing the same file on Qobuz vs Tidal? I have done it myself but only the old fashion way by clicking on versions and then selecting the other platform. Not that that process is super difficult but if there’s an easier way to do it, I’d love to try it!
FWIW, I have found that I often prefer Qobuz over Tidal but often I can’t tell a difference.
Let's restart your music server. Every thing will be ok.I’m on build 1021 and now I can’t login into Qobuz. I keep getting a message of network error? I am still logged into Tidal and streaming from there fine as well as what’s on my hard drive. But I’ve downloaded a bunch of songs from Qobuz for my various playlists and am really missing that access…
Anyone having a similar problem and found a solution?
