Do Quads wear out "all at once"?
Dogberry
Active Member
Aug 24, 2022
132
93
35
65
I have lived with Quad electrostatics for 20 years. Firstly the 989s which was not a happy experience since they failed every other time they were switched on and had to be shipped across the country for repair. Eventually the dealer gave me a good price on some 2905s to make me go away. It worked - for 15 years!
But earlier this year, one speaker started to arc, despite never being played loud and with only 40W amps. I was lucky to find a guy who could repair it just three hours away, and he replaced the failed panel and at the same time upgraded all the caps in my tube amps. Now, a different panel in the same speaker is going the same way. He tells me the glue gets brittle with age and leads to the Mylar film flapping in the breeze until it touches the stator and a new hole is born. So I'm looking at having another panel replaced, but what about the other ten panels that are left? Probably about 6kCDN to do them, and I see used 2905s for sale for less than that. I do love them, but I'm making do while they are out of service with an old set of DCM TimeFrame TF-700s, which are not bad (and to be honest, liked a lot better by my wife who keeps making comments about the monoliths from 2001).
Are there any long term Quad owners who can speak to this - is all the glue likely to be failing with age and brittleness by now?
Chris
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
Chris
Not a Quad user, but my friends are. The glue will start to fail with time. It is a lottery when it happens. It's hard to say how it will go in your case, but usually, they wear out pretty similarly. Maybe you can ask Quad if they have a better glue that you can get. That way, you would redo them but have the trust for many years to come?
Dogberry
Active Member
Aug 24, 2022
132
93
35
65
My repair guy has looked at re-gluing, and says he doesn't feel it is likely to work well. I am as torn as a Mylar film about this, as while I know how clear they sound, I also get very comfortable, very quickly, with my 30-year old DCM TimeFrames. What a shame that brand disappeared!
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
I understand it's hard to relax when you are not trusting your gear. I experience the same feeling if something is acting out in my setup.
I've looked up the DCM TimeFrames, and you can get them for very reasonable money. Do you know why they have disappeared?
Dogberry
Active Member
Aug 24, 2022
132
93
35
65
DCM had great success with their original TimeWindow speakers, and the TimeFrames were smaller and cheaper. They came in several sizes, and had a reputation for speed and responsiveness that made them sound a bit like electrostatics, or so it was claimed. That's why I bought them, but they don't really sound like Quads! Nice design, three drivers set in a flat surface angled back slightly, with a transmission line behind the largest terminating at a port lower down on that surface. I guess they disappeared because fashions apply to hi-fi just as much as anything else, and at the time speaker design was wandering into boomy Cerwin-Vega territory. They certainly didn't sound like that. Mine got regularly attacked by a cat who felt they were there to be a scratching post, so I'd better get around to finishing his job on the cloth socks, and then either re-covering them or maybe I'll just paint the MDF and leave them uncovered. No cats or small fingers to do any damage now. I've attached a pdf of the leaflet that came with them, which might be of interest.
  • DCM TF700-specs.pdf
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
Excellent impulse responses. They are well-tuned, for sure! How would you describe their sound signature?
I remember the day my cat pierced my speaker's suspension and diaphragm. Just as she did it, and I shouted at her to get off she disappeared for a week. She immediately knew what was up. I honestly didn't even know where she was hiding (I guess that was the reason for hiding) ;)
Dogberry
Active Member
Aug 24, 2022
132
93
35
65
They have very little personality - if you go from the Quads to them everything seems warmer, more rounded but less detailed. Listen to them for a few hours and you start thinking how clear they are! Auditory memory is fickle. If I have to give up on the Quads, I know that I will have an intellectual understanding that I'm missing something, but I also appreciate I won't be able to hear the difference without a side by side comparison.
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
In my experience, that description is a massive compliment for the cheaper gear. You know it's not as good, but you don't feel the need to go back to the more expensive option.
It's really good to have two way to play the music, like a flavour of the month: today I want this one :)
Dogberry
Active Member
Aug 24, 2022
132
93
35
65
I spent three hours today looking over the shoulder of a skillful repairman as he dissected a Quad 2905. It takes about 20 minutes to get the speaker stripped down to the point where you can see and test the panels. There are six separate panels, two bass at the bottom, two mid/high range in the middle, and two more bass panels at the top. For those who don't know, each panel is a sandwich, with a plastic grid of 2cm squares on the outside front and back. Inside this is a copper panel perforated by a grid of small circular holes, resting against a phenolic board like a PCB (again, front and rear). Between the phenolic boards is a Mylar membrane, glued at the edge to the rear plastic grid's outer edge. There is a 2-3mm gap between the Mylar and the PCB in front of, and behind it. The Mylar has a graphite coating all over except for the very edges. High voltage is fed into the copper stator on each side of the Mylar, and the graphite responds by by being drawn to or repelled from the stators. The stators are solid single pieces of copper for the bass panels as low sounds are non-directional. The mid range/treble panels have the classic Quad arrangements of concentric circles of the copper mesh, each part circle connected separately through delay lines so that the two treble panels act like one large concave/convex panel, simulating a point source.
All the delay lines must be unsoldered to remove panels, and reconnected afterwards.
My faulty panel, this time, was the lowest bass panel, and the phenolic board at the front of the sandwich with the copper stator on it was detached from the plastic frame at one side. Originally, it was glued in place. Careful probing with an insulated tool makes the loose part of the stator arc noisily as it is pushed towards the Mylar. So that panel was removed and replaced with a new one ordered from Mo-Fi some weeks ago.
However, the four original panels in that speaker (two now being replaced with new ones) all have the same problem developing, and all on the same side of the front face. They have come loose from the frame, but are not yet loose enough to cause arcing. Comparing old and new panels one can see some differences. The glue on the originals is slopped around a bit, but is extremely sparse or absent where the phenolic board is loose. The new panels have a visible bead of glue connecting the stator to the plastic grid.
So we scratched our heads for a bit, and discussed various glues. We don't want water based glue, and we don't want it to penetrate through the phenolic board. We decided to place a blob of industrial hot glue at each cross of the grid, and then used a dental pick to pull the copper stator back up against the glue as it set. We used one of the old panels as a test first to ensure the Mylar would not be hurt by the heat of the glue - it wasn't. Then I remembered the roasting bags for poultry, which I think are made of Mylar, so it should resist heat OK. At the end, all the stators on the front are well-affixed to their frame. None of the stators on the back of the panels were loose at all. Looks like a poor manufacturing process led to insufficient glue, and I'm guessing Quad became aware of it since the new panels have lots more glue on them. Then the speaker was reassembled and we set off home.
It works just fine now. So what was the point of the hot glue? As the end of the stator starts to flap in the breeze it gradually detaches for more of its length, and at some point it can move enough to touch the Mylar and it arcs. After a short (pun intended) while there is a hole burned right through the Mylar. By fixing the stators firmly with glue I hope we have reset the clock on those panels, or at least at that end of them, as the other end had no looseness, and nor did the rear stator as I said above. Time will tell.
As for doing it myself if needed, I think I can. There are airtight dust screens that look like Saran wrap on the front and rear of the speaker, to keep dust out (!) - because an accumulation of dust would increase the risk of arcing. The PCB with the delay coils and circuitry on it is coated in wax, probably beeswax, as it is outside of the sealed dust screens, and again any dust gathering between the terminals that the delay lines are soldered onto will encourage the terminals to arc. So after re-soldering the delay lines we dripped a beeswax candle onto the terminals. Not as pretty as the factory finish, but it should work.
Now the other speaker hasn't had a problem at all, so far. I could take it apart now and go at it with the glue gun if needed, but I think I'll wait until it starts to cause trouble, replace the panel that goes, and apply glue to all the others if showing signs of loosening. Fingers crossed, it won't happen...
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
An excellent post. It was very interesting to read! Thank you. We hope that you won't have to go through all of that again!
Dogberry
Active Member
Aug 24, 2022
132
93
35
65
And now it begins - again! After two days of non-use, I turned on the hi-fi last night and was greeted with the repetitive click of an arcing panel. I'm not sure if it is the second one up (bass) or the third one up (mid/treble), as the plastic formers under the cloth hide the arcing, even in the dark. I won't know which to install, or both, until we have it apart. Assuming both go in, and they might as well at this point, I will have replaced the bottom four of six panels. And the right speaker soldiers on with no issues at all.
So I'm back to having one Quad 2905 and one DCM TimeFrame TF700 playing together surprisingly well. I have only one functional ear so there's no concerns about stereo imaging, and I've had to move the balance control to account for the differences in sensitivity - and even with it fully turned to the Quad it it still not as loud. It is interesting to go back and forth with an (OK, my only) ear close to each. The Quad sounds smooth and complete, while the DCM seems a bit, umm, scratchy or coarse. I had expected it to be duller, and less quick, but the difference sonically is rather like the tactile difference between coarse sandpaper and fine flourpaper. Probably hard to make a definitive judgement as there is still the diffence in volume that I can't correct.
Reactions: AMR / iFi audio
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
Sorry to hear that. How long did it take to fix the panels last time? Good thing you still have something to play on.
Dogberry
Active Member
Aug 24, 2022
132
93
35
65
Not so long, maybe a couple of weeks for MoFi to awaken and send them to the dealer here, then a couple of days for him to send them to the tech, and then it's up to the tech and I to agree on a time for me to make the round trip. It's actually a pleasure to assist (aka getting in the way asking stupid questions) and chat as he does his thing. So add six hours of driving and maybe 3-4 hours while the repair is done.
This time next year, perhaps, I'll have all the panels replaced. Though since neither of the two top bass panels have misbehaved, just as none of the six panels in the right speaker have, it almost makes me think (hope) that the change in glues came 2/3 of the way through my left speaker's construction, and the right one was built afterwards.
AMR / iFi audio
2,636
1,153
260
43
UK
ifi-audio.com
I envy the option to be a part of a repair like that. Super interesting stuff. I wonder how it looks.
Dogberry
Active Member
Aug 24, 2022
132
93
35
65
I can take photos as it happens if you like?
Argonaut
2,425
1,657
530
N/A
I feel for you , I had my time with 2905’s which swung from the sublime to the Screamingly frustrated … In the end I called time and went Martin Logan CLX Anniversaries and never looked back.
Dogberry
Active Member
Aug 24, 2022
132
93
35
65
Will do. Don't know when it will be just yet, but I'll have my phone with me and that will do a good enough job.
4,702
The stator glue problem of the ESL63 type speakers is well known - we had several threads in diyaudio.com about it - see, for example, https://www.diyaudio.com/community/threads/quad-esl-63-988-2905-etc-on-steroids.318379/.
Such speakers need complete rebuilt - if this happens to one panel probably it will happen to all of them. As far as I remember one person once said he manged to re-glue the stators without replacing the mylar, but it was an isolated case. I have two old pairs of ESL 63 needing such service ... :oops:
godofwealth
600
909
108
63
I have owned Quads for 35+ years, starting from the venerable ESL 63 US Monitor, then the Gradient SW 63 with the ESL 63, then the 989, and now finally, I have three pairs of Quads: the original ESL 57, the 2805 and the 2905.
I highly recommend Kent McCollum of Electrostatic Solutions. He repaired my 2905s when one or more panels went bust. He reglued all the panels and replaced the broken ones. My 2905s are working fine for the last 3 years. Another great Quad refurbisher on the east coast is Sheldon Stokes. I bought a fully refurbished pair of 2805s from Sheldon. These have been working fine since I got them. After a lifetime of Quad ownership, here are some lessons learned.
1. The most reliable Quad ever made is the venerable original ESL 57. As long as you don’t overdrive it, it lasts and lasts. My pair is 50+ years old and going strong. Only snag: it charges slowly, so don’t unplug them. Even when I don’t listen to them, I leave them charging. They sound like no other loudspeaker. To the folks who own 57s, they cannot part with them for love or money. They sound truly better in many ways than any of the later Quads. But they’re a very hard speaker to love. The speaker sounds best sitting on its little feet. The sound projects in a way unlike the 63s or 2805s etc. you either love them or hate them. I love them, warts and all.
2. The 2905s need a big room and the gentlest amplifier you can find. I use a JJ 322 300B SET amplifier with my 2905s. 20 watts per channel. Perfect for the Quads. They sound gorgeous. Seductive in the midrange and a little ripe in the bass. Do not use solid state amplifiers on the 2905s, but if you have to, I recommend Quads own 606, 909, or the Artera. The Quad current dumping designs gave a softer treble that suits the 2905s.
3. The 2805s are the most neutral and truest of the point source Quads. If you set them up right, they are amazing. But they are much less sensitive than the 2905s. I’m guessing low 80 dBs. This raises a problem. If you play them loud, they distort before shutting down. I use a Quicksilver 8417 tube monoblock. The Quicksilvers match Quads well.
4. Always, and I mean always, turn off the Quads after listening (except the 57s). The 63s, 2805s and 2905s charge up instantly. The panels last much longer. Don‘t leave them on overnight.
Quads are a huge hassle to own. They need constant attention. They are very sensitive to humidity. They are expensive to fix. Their resale value is very poor. But their coherence is unmatched.
After a lifetime of owning Quads, I’ve moved to using a pair of Klipsch La Scalas horn loudspeakers as my main reference. My 2905s are in my dining room and my 2805s are in my guest room. The La Scalas are 20 dB or more efficient than the Quads. I use a 1.5 watt SET with my La Scalas. You couldn’t do that with the Quads. Low power SETs bring a whole new dimension. But you need 100+ dB sensitive speakers. Like the Quads, the La Scalas have very low distortion, but at far higher volumes. They are much much heavier, like 200 pounds each.
I still love my three Quads, but I would never buy another one! Talk to Kent if you want to fix your 2905s. He’s usually booked far ahead, so it’s usually several months. The 2905s and 2912s are very heavy as well. He’s recently started to decline servicing them due to their weight. It’s expensive to ship 2905s across the country. Over a thousand dollars!
