Sound Quality of new roon versions (builds)
So, after updating my Roon Core and other devices running Roon Remote, I get the following Diagnostics data for Roon Support message regarding Roon ARC:
"connectivity": {"status":"NetworkError","status_code":504,"error":"error: Error: ETIMEDOUT, response code: undefined, body: undefined connected? undefined"},
"external_ip": {"actual_external_ip":"76.169.73.200","router_external_ip":null},
"natpmp_autoconfig": {"status":"NotFound"},
"upnp_autoconfig": {"status":"NotFound"}
Ever since I opened Pandora's Box of Networking and Streaming, I feel like I've become a self-trained IT Manager. This was never a goal of mine. LOL
Mostly, I just find the gobbledygook above amusing. I have no interest in troubleshooting it.
Reactions: ihmeyers
Well if you ever want to figure it out just click on the "more info" from the Roon ARC screen.
Reactions: Gjo
I wasn't going to update from 1.8 to 2.0 as I have no need for ARC as I don't listen to music outside of my home. (unless it's Live). I then messed up yesterday and inadvertently hit the update button on my iPad and ended up with 2.0m of the Roon app. When I tried to control Roon the message popped up that since I had 2.0 of the app I would have to update Core to 2.0.
I then performed the update of my Core without any issues and also updated the app for my MacBook Pro which I used in lieu if the iPad. Absolutely no issue. The sound is as least as good as before and the laptop control does seem faster though I continue to mainly use the iPad do perform most tasks.
Still have no need for the ARC app so I won't be adding that.
My iPhone updated the app of its own accord (darn you Siri) so I was going to hold off but was forced then to go to 2.0 for Roon core.
It’s not far off what it was but a bit more tipped up and more forward. It’s not terrible but for me a small step backwards so a shade not as good. My world won’t end though as the horns with SET already makes good music easily accessible.
I may start to consider a plan B even though overall my system sounds pretty good. Might save Roon via the antipodes for the Harbeths 40.2 and consider going a different direction with the horns setup.
Is this for raat 2.0 vs. raat 1.8?
Or roon 2.0 with squeezelite vs. roon 1.8 with squeezelite?
I sincerely hope the first one :eek:
Roon 2.0 with squeezelite vs 1.8 with squeezelite Christoph… not even bothering trying via raat
it’s flattened out a bit and the tonal balance has just tilted up after it was actually good before. Nothing major but just not better for me at any rate.
  • Wow
Reactions: christoph
Oh my...
Not the answer I wanted to hear :oops:
1.8 stays for me, then :rolleyes:
Reactions: the sound of Tao
Oh my...
I guess for some systems the tilt up in tonal balance works but my system was already at what I felt was a good balanced position in tone so now it’s just top heavy and a bit detail emphatic and definitely more forward overall. Also I guess that in other servers and also through other setups and not through squeezlite 2.0 might be a different proposition altogether. If you can save a legacy version of 1.8 that would be ideal. Just too late for me to get that done unfortunately.
FYI and IME there is no tilt up in tonal balance....if anything it is more detailed and delicate...
No shift in tonal balance here either.
Reactions: Charlie B.
It may well be the server and what precedes it that influences the sound. And then we have our preferences. For example, I've read about Roon sounding slow (transient response) but with my server/Roon core it is anything but slow, at least to my ears. I would have to hear Roon in a setup that sounds slow in order to understand what that means to that listener. The really are too many variables to make generalizations.
Could you please compare 2.0 squeezelite to 2.0 raat?
To me, 1.8 raat just sounds flat, lifeless, a little edgy and simply boring compared to 1.8 squeezelite which has a liquidity to the sound, more like a real event
Well this has been a good turnaround Christoph, I also preferred 1.8 Squeezelite over the later 1.8 iterations via raat (though not the early 1.8 releases) … 2.0 squeezelite is what I was describing as dimensionally more flattened and a touch emphatic or even strident… not terrible but just not as good 1.8 squeezlite.
The good news is 2.0 raat is sounding better than both squeezelite versions again. More depth and good tonal balance and musically involving again. Glad you asked me to check it out. Thank heavens the stars are aligned back in their right place again. Here’s hoping they’ll just leave it be for a while :rolleyes:
Wow :eek:
That would be very cool.
So I really have to try 2.0 raat on it's own? :oops:
Thanks for comparing and reporting
I tried reverting to Roon 1.8 legacy which took me down a rabbits hole that I couldn’t really get to work before I returned to Roon 2.0 and after your prompting I’ve now settled on 2.0 raat… I’m glad it’s where I’ve ended up though as the prospect of hanging out on an unsupported legacy version is not that attractive and one where you’re likely living on borrowed time at any rate. Uncertainty seems to be the continuing theme of this current age and contemporary life.
Wow :eek:
Please update after discovering if 2.0 is passable in your bathroom system. :p
This is a valuable remark. Not sure if it is possible given how the program is structured. At least not in ways I'd openly divest.
Though I appreciate that digital is still in a period of active improvement. I remain confused by how many here pursue active use of a program that changes so often. There appears to be no systematic regularity.
Two things:
- The core will be the same for all the systems
- I don't have a bathroom system
:D
Reactions: rando
