I assume you are using the AC wraps on your power cables? One end or both ends? Could you comment on the differences you have heard?
Trying to decide on next upgrades.
Thanks
So I am just trying the new Entreq blocks (like super-powerful Magma Feet...about 2x the size...but without the disc in the middle because they are not actually feet but more of a single large block that can itself be grounded but has apparently a more powerful version of the effect that Magma feet can have through their proximity to fields.
In any event...only just placed them near IEC and DAC to see how it works...will update later.
As for the wraps, yes, I place them over the IEC as it ENTERS the back of the unit. I have on occasion placed one on the wall side (for example, we have a 16-amp special outlet that powers the big Torus which powers the ENTIRE system, so we wrap both ends of the power cable).
Overall: I have preferred/found better of the same effect when placed closer to the IEC than wall-side
- calmer, definitely calmer
- rounder/more palpable notes...rounder as in more 3D, more real, more palpable (not rounded off)
- quieter...definitely seems to allow more detail to float out of the music stage
Hope that helps.
