That cartridge looks absolutely stunning. I could just look at it for a whole day. I'm looking at Phasemation PP-200 and Nagaoka MP-200. It's probably going to be the latter, due to the price. I believe PP-200 might be the cheapest Hi-End cartridge out there. At least for me.AMR, well yes, there should be 2 rooms if that happens, but I do not have 2 rooms now.Agree with your notes on active subs, it's the way to go for a full range feeling. Yes, I'm fine with the electronics. VAC preamp and Jadis amp work well for me. A long long shot of a dream project would be getting another turntable/arm/cart combination as a 2nd rig, and what I have in mind would be an Acoustic Signature turntable with a Triplanar arm and a Koetsu Jade, with a possibility of adding a Koetsu SUT in between. Thanks for inspiring me to dream.
Indeed the Jade looks gorgeous. Have not heard a Phasemation here so far though.That cartridge looks absolutely stunning. I could just look at it for a whole day. I'm looking at Phasemation PP-200 and Nagaoka MP-200. It's probably going to be the latter, due to the price. I believe PP-200 might be the cheapest Hi-End cartridge out there. At least for me.
How would you describe the difference between Maggies and Quads?
So you got seriously fed up with the Jadis (dis)service. I fully understand.The ARC 160s - Full circle with Audio Research
I started my high end journey in the mid 80s with an ARC D-115 MK2 power amp and SP10 Mk2 preamp. Somewhere down the road, VTL, Conrad Johnson, and Jadis joined my audio stable. Then went back to 2 ARC amp models and another Jadis model, and now, one of the latest ARC amps made by this illustrious company, the Ref 160s.
On another thread, I had shown my displeasure over the biasing method of the Jadis PA100 amp and I had been searching and scouting for a good back up or an eventual replacement. A few weeks ago I was alerted by the former local ARC dealer that they have some stocks on a going out of business 'sale'. I noticed the 160s and took interest. After more readings, a deal was reached.
View attachment 98037View attachment 98038View attachment 98039
It looks pretty, or handsome as they would call it. Auto Bias all the way, using 8 KT150 tubes for a total of 140w. Has a Triode (70w) and Ultra Linear Button. That's interesting. It has a tube cage which I normally remove when using, for better air flow. It also has the touted 'ghost light meter'. A sight to behold. I'll be spending some hours burning them in before making serious listening.
Thanks, Christoph.So you got seriously fed up with the Jadis (dis)service. I fully understand.
If the ARC sounds only have as sexy as it looks, you will be very happy.
I really wish you more luck after the Jadis desasterThanks, Christoph.
Thanks, Mike. That's a nice idea.Congrats Phil, no more fussing around with self-biasing.
Just for kicks, at some point in the future, try the KT-88s from Jadis(less power for sure) to see what you hear about the differences in sound on power tubes.
Now you have to change your screen name...Initial findings. First hour could actually break one's heart, if he didn't believe in the burn in/break in phenomenon. There was practically no bass, and the soundstage is a bit squashed to the middle. There is depth but no width. And I was wondering if this thing is really 140w.
Fast forward to the 10th hour, and amazingly, everything came in, as in everything. Bass was stout and full, sound was so alive and balanced, width showed up and there was a full stage, peppered with instruments. And the power, it felt strong. This is more like it.![]()
Thanks.Now you have to change your screen name...
Congratulations!
When I had the 160Ms, i found it quite a roller coaster during breakin, which can take at least a few hundred hours to be fully settled. The good thing is continuous improvement lies ahead, with some bumps in the road where you’ll have an occasional night where things don’t seem congealed at all, or flat, or dull. Then back the next day and viola! everything is back and sounding even better.Initial findings. First hour could actually break one's heart, if he didn't believe in the burn in/break in phenomenon. There was practically no bass, and the soundstage is a bit squashed to the middle. There is depth but no width. And I was wondering if this thing is really 140w.
Thanks Bobvin. You are right, there is continuous improvement going on. And I am hearing its 'power' coming in. It's quite powerful now,When I had the 160Ms, i found it quite a roller coaster during breakin, which can take at least a few hundred hours to be fully settled. The good thing is continuous improvement lies ahead, with some bumps in the road where you’ll have an occasional night where things don’t seem congealed at all, or flat, or dull. Then back the next day and viola! everything is back and sounding even better.
Thanks, Gerard. Well, I have used 2 ARC amps prior to the Jadis amp and this 160s. Those 2 ARC amps, compared to this 160s, are more 'upfront', forward and lights it up in front of you, This 160s is more laid back, relaxed, and is superior in soundstage width and depth. I have added some things since day 1 of the 160s, like a 3" solid wood base, then a change from 4 ohms to 8 ohms (my bad, the Quads are 8 ohms), then adding a long Furutech power cord to run the 160s to the middle of the room where the p12 power plant meets the front end power cords, and now, putting on 4 Center Stage feet under the 160s. Amazing, that each change would result into an obvious increase in bass, spatial expansion, and detail. And I'm just at 50 hours. Yes, Maggies and Quads have the same sensitivity @86db and power is good for them. 150w thereabouts is enough. It's tougher to compare the Jadis PA100 to the 160s because the difference is so close. The Jadis is quite a beast too, sonically. In the end, I figure that the differences in both would be attributed to my use of NOS Telefunkens and Mullards on the Jadis amp. The ARC 6H30 small tubes cannot be rolled into these types.Fascinating journey Phil. Like many of us it is a journey which often pauses at points but then continues. Like you I have a love of the planar sound. I have owned boxes, SD1s in the 80s with ribbon tweeters, B&W 802s wigh the sealed bass units ( very power hungry...killed my valve amps) but kept coming back to planars.
I do wonder if you now you will notice tthe difference with new ARC. I my experience Maggies and Quads need a lot of power and current. Something I have struggled to achieve with valves. The only amp that has come close (but could not drive the B&Ws....just motorboated) was a Beard P101.
One of Rogue Audio 120 monos, like your story, flashed an caught fire....driving Maggies. KT88s were fine, not so the melted pcb, resistors and caps!
I now run solid state and plenty of power .
Enjoy.
P.S. I do like your room.
Actually the 6h30 can be substituted with a Russian (if available due to the war), with a 6h6 (6n6p). They are very inexpensive. Sound wise they are slightly more relaxed sounding than the 6h30 “Super” Tube.Thanks, Gerard. Well, I have used 2 ARC amps prior to the Jadis amp and this 160s. Those 2 ARC amps, compared to this 160s, are more 'upfront', forward and lights it up in front of you, This 160s is more laid back, relaxed, and is superior in soundstage width and depth. I have added some things since day 1 of the 160s, like a 3" solid wood base, then a change from 4 ohms to 8 ohms (my bad, the Quads are 8 ohms), then adding a long Furutech power cord to run the 160s to the middle of the room where the p12 power plant meets the front end power cords, and now, putting on 4 Center Stage feet under the 160s. Amazing, that each change would result into an obvious increase in bass, spatial expansion, and detail. And I'm just at 50 hours. Yes, Maggies and Quads have the same sensitivity @86db and power is good for them. 150w thereabouts is enough. It's tougher to compare the Jadis PA100 to the 160s because the difference is so close. The Jadis is quite a beast too, sonically. In the end, I figure that the differences in both would be attributed to my use of NOS Telefunkens and Mullards on the Jadis amp. The ARC 6H30 small tubes cannot be rolled into these types.
Thank you for the advise, Mr Jazz. I will be looking into that tube substitute. I had used gold pins premium EH Russian 6H30Pi on my ARC VS115 before and I couldn't really tell the difference over the stock Sovtek tubes. This 6h6 looks interesting.Actually the 6h30 can be substituted with a Russian (if available due to the war), with a 6h6 (6n6p). They are very inexpensive. Sound wise they are slightly more relaxed sounding than the 6h30 “Super” Tube.
Depending on what direction you want to move the sonic “goal posts”, they might be worth looking into. I used them in a Ref 6SE preamp with good results. They might behave differently though in the 160s amp.
Cheers....
