When a Tweak becomes something more
PeterA
12,670
10,944
3,515
USA
Nothing in any of my posts says or implies that I am interested in a “particular type of sound”, nor did I dismiss all industrial cables-just the ones I’ve heard-including Ching Cheng. However it stands to reason, and my ears confirm, that cables designed and optimized for audio are going to sound more like music than cables designed for appliances, computers, etc. Again, I expressed curiosity as to whether or not there were particular Ching Cheng cables that were preferred by WBF posters since the ones I’d heard sounded like crap. That’s it. I am not searching for cables. I have optimized power cables for each individual component and am happy with the full loom which provides extraordinarily resolving and natural sound.
It sounds like you’re very happy with what you have. There is a particular Ching Cheng power cord that some members here and elsewhere use in their systems. There is a photograph and model designation further up the thread. It is no longer being made. You could try to contact some of the people who have them to see if anyone is willing to send you one to audition to satisfy your curiosity. Alternatively, someone might invite you to hear his system and you can bring your cable and compare them. This is how I’ve heard my cables in various systems and other cables in my system.
Cellcbern
1,224
733
585
71
Washington, DC
Thanks-but it is not that important to me. I was just curious.
Kingrex
2,952
2,435
350
I still have the Oyaide in place to my phono. I am very happy. Oddly, this power supply tweak, as well as the Deoxit has helped my Allnic H1201 get to a place I am not so dissatisfied with. I am not in such a rush to change it out. Its surprising how much the wire in the wall and the cord matter. But they do. I will put the CC back into play in a couple days to get a better feel what it brings. At the moment they are both back on the tape deck to the outboard NAB/IEC/preamp.
jerrybj
281
152
48
61
New Zealand
Maybe the more important question is, where do you start. What really matters. What do you have to have because it's a foundation to good sound. A fuse????.
Going backwards, here are recent purchases which could be/have been significant in their improvement of my system.
Some are components, some tweaks, some cables.
1. Audience AU24Sx AES/EBU cable (to arrive)
2. Auditorium 23 speaker cables and jumper cables (to arrive)
3. Audio GD DI-20HE DDC - a rather large step
4. LHY OCK-1 master clock - 7 days on it, but to be evaluated
5. Gustard C2 clock cable (to arrive)
6. Gustard A22 Dac with Coherent Systems mods (to arrive)
7. Cisco SG110D-08 network switch with Fidelity Audio C4Mk2 clock - a large step
8. Triode Wire Labs Freedom ethernet cables
9. Akiko Audio Fuse Box Pro - in place
10. Mad Scientist Black Magic Ultra USB cable - a good step
11. Add Powr Symphony Pro/EAU2 (to be evaluated)
12. Pink Faun Lan Isolator and Acoustic Revive RL1 Lan Isolator
13. Synergistic Research Purple/Orange fuses to amp, Dac, power supplies
The Audio GD DI-20HE DDC and LHY OCK-1 master clock will end up with Coherent Systems mods.
Perhaps will be unable to ascertain the effect of the Akiko Audio Fuse Box Pro, as it is in place.
All others can be removed to decide how they affect my system and if I like what these differences are.
So far the best recent purchases are the Audio GD DI-20HE DDC and the Cisco SG110D-08 network switch with Fidelity Audio C4Mk2 clock.
Atmasphere
2,378
1,867
1,760
St. Paul, MN
www.atma-sphere.com
If the equipment in your system employs no feedback it will be far more sensitive to things like this than if the various components use a lot. Feedback if properly used will allow the equipment to reject lots of influences; you need a lot of feedback for this to be so. My understanding is that the equipment you tend to use is on the lower/zero feedback side of things.
The amount of power drawn seems to make a difference as well. Power cords, AC outlets and the like really affect our MA-1 amplifier (a triode, class A2 OTL) a lot, which draws a lot of power and is zero feedback. But they hardly affect our class D amp at all, which makes about the same power but draws significantly less power and employs a lot of feedback.
If people are not paying attention to the issue of power draw and feedback used (as well as power supply regulation) then something like a power cord will have highly variable results depending on the system. I just thought you might like to know why those differences can be so profound.
Reactions: PYP
16,224
13,691
2,665
It's always going to be a bit of a WAG whether or not one can hear a guaranteed improvement following someone else's guidance, . . .
What is a “WAG”?
MarkusBarkus
1,015
1,674
258
66
A WAG is a "Wild Ass Guess" in software dev parlance. Probably used in other areas too. Sorry for the jargon!
16,224
13,691
2,665
Tuckers
320
257
310
55
I have a couple of those Ching Chen cords, purchased back in the day from the right sources, the ones with the clear plug. They did sound neutral but were nothing special, did not soundstage or have depth. The one advantage I found with them was that they were a bit lean in the bass, but very taught and tight showing off the shape of the bass well. So they found a home powering some dual subwoofers I had, where those qualities were a good fit. These days they power a couple of non-music PCs.
