Converting Ripped SACD Files to DSD
astrotoy
1,551
1,020
1,715
SF Bay Area
If you are trying to create multichannel files (these are huge) then I think you need to first create .iso files and then decode them to stereo and multichannel separately. I use my tried and true PlayStation 3 to create the iso files from the SACDs. Then use the Sonore to complete the conversion. I found there were some problems with the earlier Sonore versions that wouldn't decode a few files. But the new version does fine. Larry
Reactions: Alrainbow
Alrainbow
3,260
1,431
450
I won’t make any roon buds but someone has to say things as they are
for one the room gods are selfish and say things they can’t do or were wrong to say and don’t care.
many players play iso files fine
foo bar, j River for another
next the conversion process to create diff or dsf files changes the sound. The software you use truncates the data to approximate the files Then adds data to allow you to play the files. I’m not an ultra nurd but did this many years back and I can hear the effects
the best way is play the iso is as is. What they do I have no idea but they sound the same always, meaning no variation in software sound.
you can’t see the track names or info until it’s loaded.
i love the features of Roon like most , but each revision is an up and down sound. one format is better and others now suffer.
for me Roon is a nice simple player loaded with great info
but sending to another end point of sorts is a must
and there are other players not as cute but sound amazing in compares as is.
hq is min to use Roon but hq while by is far the best player in sound
is a mindfield of menus to sound best.
i know taking the time to make each album be best matters. But man I’m old and playing cd s to a good dac is also a great simple no fail to play music too.
  • Love
Reactions: rando and dan31
rando
1,705
1,240
245
Online
As in most things the only way to improve is keep trying. Software has and will continue to make strides. :)
ACHiPo
519
309
310
Pleasanton, CA
I received the dual "A" USB yesterday, but didn't get a chance to try it. The bridge arrived today and I had a few minutes so I installed it. Easy peasie! And fast file transfer from the Aurender.
ACHiPo
519
309
310
Pleasanton, CA
I got back to converting SACDs to DSD, but it seems like setmind/SACDExtractGUI no longer works. The link takes me to a java code site. Does anyone have a version of the program executable they can send me or provide a link? Thanks!
Kal Rubinson
2,362
706
1,700
NYC
www.stereophile.com
See Releases / Latest over on the right?
ACHiPo
519
309
310
Pleasanton, CA
In the immortal words of Emily Latella, "never mind". Or as Homer Simpson would say, "D'oh!"
Thanks Kal!
Reactions: John T
ACHiPo
519
309
310
Pleasanton, CA
Thanks Kal!
PS it works great now. Now if I only had the skill and patience/time to write a script or command line to convert the remaining ~400 albums. Oh well, 6 more down, 394 to go…
I have a couple weeks off coming up. Maybe this will be one of my projects. The XDMS sound quality is certainly quite an incentive.
Kal Rubinson
2,362
706
1,700
NYC
www.stereophile.com
Why do you need a script when you have a GUI?
4,704
It is a ridiculous situation - hundreds or thousands of SACD owners having to loose their time to rip their SACDs one by one generating each one exactly the same files. There is considerable progress in CD ripping - some servers will automatically rip an entire library in short time, why no one has developed a similar system for SACDs?
Reactions: ACHiPo
ACHiPo
519
309
310
Pleasanton, CA
Kal,
It takes about 90 seconds to convert the file and 10-30 sec to enter the info, so about 2 minutes per album assuming I'm vigilant and don't get distracted doing other tasks while the conversion is going on. Without automation (script or command line) that's over 13 hours of, what is in my mind, non-value-added time (other than the value of hearing an SACD title on my Extreme via XDMS, which is quite an incentive).
Evan
ACHiPo
519
309
310
Pleasanton, CA
Well, in all fairness, the Aurender played my SACD files just fine...
Reactions: GSOphile
ACHiPo
519
309
310
Pleasanton, CA
Enter what info? I just click and go.
I have to select the folder and file, destination location. I also often need to find and copy cover art which is not a show stopper. I'm sure I could get the info entry time down a bit with practice.
Kal Rubinson
2,362
706
1,700
NYC
www.stereophile.com
???? That's automated in the GUI if you set it up.
True. I use Album Art Downloader but I do that in batches.
ACHiPo
519
309
310
Pleasanton, CA
That's what I meant by script or command line. I just haven't taken the time to figure out how to "set it up" to automate it.
ACHiPo
519
309
310
Pleasanton, CA
