Ajajajja Marty - you’re xyz times worseJeez, I thought I took on some considerable tube rolling projects, but compared to this...I am not worthy!!
Isn't that the same?Either that or “deep debt“
Wowza on the WE 422A! That is one damn hard tube to find!- Recti : Western Electric 422A ( tried KR 5U4G RK, Takatsuki 274B, Brimar 5U4G,Marconi, GEC U52)
- Output : Mullard EL34 xf2, (tried TS KT170, Mullard EL34 xf3, KR KT88, Gold Lion KT77( stock), Bendix 6384)
- Dual triodes : Mullard ECC32 or Visseaux ecc31 both are exceptional tubes (tried psvane, linlai 6SN7, Thompson 5687WA, Meltz, 6H8C)
that’s the key. Totally system dependent and also personal preferenceSynergy
(...) During this whole testing process, I kept the volume level at 30 and played the same group of songs which I can tell you now my wife is sick of hearing. The majority of these tubes have not ever been discussed in this forum so in a small way I hope this helps.
This has been my experience as well.When rolling tubes I have found I needed to change level to have the same measured loudness in equipment having no global feedback loop - I had variations of up to 4 dB just using different tubes, up to 2 dB when using the same type of tubes .
I did the same thing. I started at 30 and then if I thought the tube did not deliver I did raise the volume between 34-37. Right or wrong, I did use that as a negative when listening.When rolling tubes I have found I needed to change level to have the same measured loudness in equipment having no global feedback loop - I had variations of up to 4 dB just using different tubes, up to 2 dB when using the same type of tubes .
Hearing all these joyful descriptions of tube rolling made me realize the true genius of Lukasz lies in more than creating a wonderful series of DACs. What he did was unleash this TRP zeitgeist within all of us to experiment, to discover new ways of tuning components by tube rolling. Although tube DACs have been around a long time, ARC has had tube DACs for decades, no one before Lukasz made it so easy, indeed encouraged tube rolling.
ARC officially frowns on tube rolling, as do the other established companies like Conrad Johnson, McIntosh etc. Lukasz was probably one of the first to unleash the TRP gene in all of us. Who doesn’t want to feel like they have a moment of creativity in finding a new tube combo that works in their system. The established brands are so superior in their highbrow attitudes. ARC and other companies say: WE have decided what tubes go into our products. You listen to our choices because WE decided that‘s best for you.
Lukasz decided early on to encourage tube rolling. As the old Latin phrase used by the Roman poet Virgil in his famous poem Aeneid says:
Audente Fortuna juvat. (Fortune favors the brave), Book X, 284, Virgil, Aeneid
P. Vergilius Maro, Aeneid, Book 10, line 276
www.perseus.tufts.edu
You will be blown away by the sonic gain possible over the Blue Tennis BallsThank you for sharing !
Now that many people had their Horizon for some time, I was wondering if we could briefly share the combo we are using ( and list what wehave tried ).
On my side, didn't do much tube rolling yet...
- Recti : Tak 274B ( tried KR 5U4G RK and EML 274B)
- Output : TS KT170 ( tried KR KT88)
- Dual triodes : the provided Psvane blue balls ( didn't try anything else yet but will start soon)
I wasn't impressed with it either when we played it at my house with Lukasz. In fact after everyone left I texted Lukasz and told him I was going to keep looking for a replacement to the KT-170. It was then that Lukasz told me I should not give up on it so fast as h thought it to be a very good tube. Im happy I took his advice because once it settled I ended up buying 2 more back up sets. It mates really well with my Tak 274B and TS 6SN7 GT VT231 round plate. I have several back up sets of these as wellI did the same thing. I started at 30 and then if I thought the tube did not deliver I did raise the volume between 34-37. Right or wrong, I did use that as a negative when listening.
@ Sampijanna
I did not compare the TS6550 to the KT 170. Again, maybe I made a quick decision but when I heard the KT 170 at the launch at Steve's house it did not sound good. It was pointed out at the time it was a brand-new tube and not broken in. I am really happy with the TS 6550 NOS tube.
I did the same thing. I started at 30 and then if I thought the tube did not deliver I did raise the volume between 34-37. Right or wrong, I did use that as a negative when listening. (...)
I am sure. I "just" need to find a reliable tube seller of NOS tubes as so far I only bought "modern production" tubes for my gears...You will be blown away by the sonic gain possible over the Blue Tennis Balls
You raise a key point which is the distinction between a seller of NOS tubes and a reliable seller of NOS tubes. Many of us rely on Brent Jesse, who is excellent and reputable.I am sure. I "just" need to find a reliable tube seller of NOS tubes as so far I only bought "modern production" tubes for my gears...
