Long Run Speaker Recommendation Appreciated
Labpro
56
49
85
Boston
Those of you with "odd shaped" listening rooms will appreciate my predicament.
I have an "L shaped" listening room and decided to move my speakers along the longer wall while leaving my components along the shorter wall.
This set-up works better, with the Vicoustic and Acoustic Sciences (ASC) treatments I have on hand.
However, this necessitated my needing 5 meter speaker cable runs.
System Overview:
Horn speakers 97db into 6 ohms
Mono 300B amps - 8-10 watts
Tube preamp
Mostly listen to vinyl using a SUT with a MC cartridge
While I'm not an Engineer, I've tried to learn about capacitance and inductance in order to select a cable that will sound great even at longer lengths.
I've read all of Jeff Day's reviews of the Duelund tinned copper cables, and in fact tried a 5 meter pair of 16g with fairly good results. In my system, they sound "lean" so I may also try the 12g Duelund as Jeff suggested.
The rest of my interconnects are Audience Front Row except for Shindo silver interconnects from preamp to amps.
I have always had silver speaker cables until trying the Duelund copper cables recently.
I'm looking for speaker cable recommendations.
One challenge is that few (if any) dealers or Mfg keep 5 meter "demo cables" around. I really must hear them in my system before buying.
My budget is $3K-$4K.
Thanks for the assistance.
Reactions: McDee275
Labpro
56
49
85
Boston
Hi Cesar Miranda. Unfortunately my dealer only has a 4 meter pair. In any case, I plan to try the A23. In my last system they were a bit too laid back for my taste, but I have yet to try them in my latest system.
Reactions: Cesar Miranda
Labpro
56
49
85
Boston
I like Luna, and in fact I have a couple Rouge interconnects. However won’t they be too “restrictive” for long 5 meter speaker cable runs?
Reactions: Long Live Analog
henrich3
Active Member
Jun 7, 2022
139
103
35
Scottsdale, AZ
At your 5 meter (16 feet) distance, any competently-designed speaker cable that's 14 AWG or better should be fine as long as your speaker's impedance is 4 ohms or higher. I personally wouldn't use speaker cables smaller than 12 AWG since it's a trivial additional expense. Beyond that the considerations are just aesthetics, brand preference, and price.
https://www.audioholics.com/audio-video-cables/speaker-wire-gauge
http://www.roger-russell.com/wire/wire.htm
Reactions: antigrunge
Long Live Analog
155
132
50
62
West Tn. Mid South
I’ve got the Rouge ic’s also and the Mauve speaker cables at 4 meters. No problems at all. Electronics are Gato with Aerial Acoustics 7t’s which are 4 ohms.
Labpro
56
49
85
Boston
Interesting….especially the 4 meter speaker cables. Your Gato amps put out a lot more power than my western electric 300b’s. I’ll bet that must be the difference.
Solypsa
1,811
1,401
275
Seattle
www.solypsa.com
Could look at Gotham 50150 specs. Pro cables like this at least document well ;)
Labpro
56
49
85
Boston
Thank you. I have heard good things about Gotham. I’ll definitely look into it.
Long Live Analog
155
132
50
62
West Tn. Mid South
Another speaker cable I’ve used with success is Ortofon. No problems with the distance. Erik and Danny at Luna can advise which cable will work best if you decide to go that route. I worked with them and my dealer to get the right combination.
Labpro
56
49
85
Boston
Ortofon….I’ll look into it. Yes Erik and Danny are great.
Alrainbow
3,260
1,431
450
can’t you place the amps near the speakers ? 16 foot speaker cables no matter makes them have inherent specifications that may work against the amps and not to the benefit of the speakers. Long runs beyond 6 feet can make amps un stable.
larger gauge wires does not fix the problem where larger gauge wires can have a negative effect compared smaller
More inductance is added this clamps dynamics. I’ve seen a ribbon type speaker cable this might inductance over all.
Labpro
56
49
85
Boston
Good point about using long run interconnects and shorter speaker cables. Unfortunately my preamp uses a custom Shindo interconnect….and it’s only about 1 meter.
Alrainbow
3,260
1,431
450
Lol wow. I’m not trying to make this a bad idea just being honest I don’t sell any products lol. one thought might be place your devices in front as a temp idea to see how well the new setup works
Labpro
56
49
85
Boston
Alrainbow, I believe you are asking if I considered moving the entire system along the "long" wall. I can certainly do that, but I really like having the components separated from the speakers. Plus I'll need to get an electrician to re-do the placement of the dedicated lines. Today I ordered some Duelund 12g plus I'm going to explore some of the recommendations everyone has made. Since the Duelund only costs $400 I have $$$ to explore some other options too.
Alrainbow
3,260
1,431
450
All
I’m saying is to test the location as simple as possible
I’ve done this myself a few times
I like you have nothing behind my IRS v now and the equipment on one side like you are thinking
AudioHR
231
210
90
71
High River, Alberta Canada
Interesting discussion. Personally I prefer not to have all my components between my speakers so I run longer interconnects rather than longer speaker cables. I am sure there are pros and cons to this but my experience has me in the longer interconnect camp.
Having said that a 6 - 8 foot speaker cable would seem to me to be a fairly common length. Is it possible that there was a typo when you said " long runs beyond 6 ft. can make amps unstable" ? Or perhaps this is a legitimate concern that I was unaware of?
abeidrov
VIP Donor
Dec 17, 2015
707
341
443
Moscow
System Overview:
Tube preamp
You might try Belden 9497 just for fun:) It is available at different lengths, I bought mine from this guy:
Belden 9497. It may lack some audiophile qualities, but the fact is that I’ve been using this cable for the last 3 weeks, and I do not want to switch back to my expensive audiophile cable, I just want to continue to listen and enjoy the music.
