Lamm Repair?
ddk
6,261
4,043
995
Utah
Any one has news on the Lamm move to Florida? When are they expected to be back in normal operation?
The new factory/showroom is under construction and they estimate end of November for the soft opening. Currently they’re accepting service items at their temporary location, also in Florida.
david
Fishfood
537
541
255
44
Anyone had a recent experience with Lamm repair? I need to send in my LP2.1. One of the RCA jacks is broken. I'm wondering if it's better to have a local tech just replace it?
tima
5,869
6,945
1,400
the Upper Midwest
In April ...
Repairs are being made right now in Florida by the Lamm service department. I just spoke to Elina Lamm on Thursday.
Reactions: Fishfood
theclipper
35
11
13
39
Have any other LP 2.1 owners dealt with noise issues? I've got some hum/noise that is loud enough to be heard over very quiet parts of music from the listening chair. This isn't my recording, but it pretty much sounds like this:
https://www.dropbox.com/s/faxmop972rok7i1/Noise.m4a?dl=0
It's pretty much equal in both channels, and gets louder as the volume is turned up. I emailed Lamm and they claim it's normal, which doesn't seem right. As a test I tried floating the ground with a cheat plug, it didn't make any difference.
To rule out the cart, turntable, etc - I put another tubed phono stage into the system and it is whisper quiet with the same gear attached.
Not really sure what to do since Lamm didn't think it was an issue.
  • Wow
Reactions: Argonaut
rich121
100
41
133
Washington State
Did you try fresh tubes? My LP2.1 has no noise.
theclipper
35
11
13
39
I'm going to dig some out this weekend, I believe I have a backup set. The fact that it's coming from both channels & there isn't really any tube noise coming from the tweeter made me think it's less likely a tube issue. Though I should definitely rule that out.
It sounds like a ground loop hum to me. Very common with phonostages Have you grounded the LP 2.1. Not that it’s a fix but try putting a cheater plug on the PC of the LP2.1 or try using a different AC outlet
theclipper
35
11
13
39
I've wondered if it might be a ground loop, though I can't seem to affect it. I've tried grounding the LP 2.1 directly to the preamp and then have also tried grounding it to my Shunyata Denali, but neither has made any difference. I also tried throwing a cheater plug on the LP 2.1 power cord, but it also didn't make any difference. Have tried the LP 2.1 directly into the wall, as well as different outlets in the Denali. So I'm stumped at this point.
theclipper
35
11
13
39
Yeah, I've tried it in a few different outlets in my room. Still haven't been able to get the issue to change. Any other obvious troubleshooting/diagnostic things I might be overlooking? Not really sure what to do at this point.
tima
5,869
6,945
1,400
the Upper Midwest
I'm confident that if Lamm understood the issue as described they would not say it is normal. Feel free to PM me their e-mail reply, don't post it in this thread.
Is your unit new or used?
How old is it?
When did the 'noise' appear?
Does the noise occur with both MC and MM inputs or just one of those?
When was the last time you changed tubes?
Since a tube change is less cost and effort than a repair, I suggest swapping in a new 6x4 rectifier tube in the power supply. That can be a 6X4W, 6X4WA, 6202, EZ90, CV4005, CV493. Maybe that will help, maybe not.
The LP2.1 is a very quiet phonostage.
theclipper
35
11
13
39
How old is it?
I bought this unit used from another forum member. I believe it's around 5 years old.
The noise has been present since the first day I received the unit. I've pretty much always been able to hear some hum between tracks, and when nothing is playing. Recently, I've been testing out a new SUT which has allowed me to play at a louder level. Unfortunately the amount of hum/noise also increases as the volume is raised, to the point where I can hear it over very quiet parts of music.
I've swapped out all the tubes within the last few months, it did not seem to make any clear difference in the amount of noise being generated.
This is present on both inputs, and seems to be at pretty much the same level (when volume gain levels are equalized with a dB meter).
I will shoot you a PM once I can pull up Lamm's email to me.
Thanks much.
