I hope it helps by your turntable stand project!Very nice project! Thanks for the detailed description.
Adding Vaseline to the belt? Really?? Wouldn’t the belt slip with lubricant?Every turntable is a high sensitivity vibration measuring tool. Only, at KRONOS level to get all available performance out of the system you have to be much more sensible about every detail, as I had written. What you normally do not know if you do the set up by yourself is, where the traps are. In this morning I learned more clearly than before that managing vibration is what matters. The general performance is done with the turntable development itself. But you have to know where you have to tight the whole framework by screws and where you have to loose the screws. Often something between. Before, by advice through Aristomenis, I purchased a highly sensitive torque screwdriver from a good german company. Using the nominal correct torque was good, but not good enough. Evaluated by hearing we could clearly hear if the torque was correct or better a bit e.g. looser. Simplified, most time you unlock the screw and turn carefully until the very first resistance in your hand. But not too loose. Crazy.
Congrats on the new table/arm! It certainly looks like an impressive piece of machinery. I heard the Kronos several years back at the AXPONA Show near Chicago and I thought it did an excellent job, even in unfavorable show room conditions. I believe it rightly deserves a seat at the round table along with several other top tier tables.I have heard different opinions about the KRONOS. In some statements (also in the WBF) the KRONOS is O.K., some are outstanding. Why is this? I always wondered about the variating opinions. Why is it that professional reviewers give to the system this positive reviews?
Here some examples by short www-search:
https://positive-feedback.com/audio-discourse/impressions-kronos-pro-le-turntable/
https://www.monoandstereo.com/?p=1459
https://www.hifi2die4.de/images/presse/pdf_artikel/2015/Kronos Pro.pdf
Different rooms, different electronics, marketing budgets? No. I don’t think so. For KRONOS as a turntable in the top league (and like everything in this level) counts the statement of David Wilson EVERYTHING MATTERS.
