Do not want to take too much ‘ space’ in Ked’s thread but in short: I have a Kondo m1000 mk I with built in phonostage available in the Genesis 1.1 system. Still a beautiful sounding piece of equipment. In the LA system I am using a Kondo g-1000 linestage. In order to be able to play vinyl I have to add a top notch phonostage to the LA system and off course I need space for one of my turntables. I play single ended so no possibility to place the turntable far away from the phonostage. That is going to be a challenge. Furthermore the digital (at least the Wadax combo with all the special ‘features’ I have built around it) sounds to my ears really great. So for now I leave my Decca sxl’s and EMI asd’s in storage, but who knows what the future will bring?![]()
well you can use the M1000 or if you want to spend get the G10. There are less expensive phonos as well. I think that you have a lot of options for to easily sort out. Main thing is to get the TT out of storage and set it up. The accessories, etc. Surely the the best demo of grounding will be if you can demonstrate to your visitors that grounded digital can sound better than non grounded vinyl playing Decca SXLs etc
