Wow @luca.pelliccioli ! that sounds like the Gold Standard of music network!
I am evaluating the Switch X replacing my JCAT M12 Gold. So (repurposing) my M12 I inserted it between my Verizon Modem and the Switch X.What I found is that if I doubled up on the switches, one switch after a standard router feeding ones audiophile switch that the internet streaming performance was very close to direct streaming from a decent music server (pink faun in my case).
So when I purchased the NA switch I repurposed my existing audiophile switch for it to come before it and connect to the router first.
Daisy chained switch… I asked Innuos team their opinion about putting a second PhoenixNET in the chain, they do not recommend doing that. It could’t worth the money. Said by the manufacturer itself.
Other members here had different results, though.
Personally I think there's a balance of sound quality, price and esthetic in play. I'm listening to music in my living room, I don't want it to look like some kind of science lab with switches and cables all over the place.
Nice one mate ! Bit of a relief that I did not mess up in my recommendation of it. Enjoy it in good health, keep us updated.The new Tempus switch is just amazing! Giving it just a few more hours and will post my review then.
Would be interesting how these two compare to the ifi Silencer and Audioquest Jitterbug FMJHi @luca.pelliccioli, thanks for that, Yes, I'm aware of the CAD USB control. It's just that it was easier to get the Telos in Australia and cheaper. The only thing the Telos needs is an Active USB port to work with. Now the CAD does not require an active USB port, and since my CH C1.2 does not have an active USB port, I just ordered the CAD USB Control for my CH C1.2. I was planning to get one anyway.
Cheers - have a lovely day
Another alternative on the USB side. https://wyred4sound.com/products/iso-recoveryWould be interesting how these two compare to the ifi Silencer and Audioquest Jitterbug FMJ
Don’t think this is what would fit into the USB port of a switch and further drain away noise. Therefore looking for short USB sticks with the functionality. Having already ones from Audioquest and Ifi I am just curious to compare others too to maybe improve things even more.Another alternative on the USB side. https://wyred4sound.com/products/iso-recovery
Oh you are using a laptop or a computer. actually yes with 2 short usb runs. I use this with my Innuos Zenith and runs to my LessLoss Echos End DAC. No pc or laptop in the chain.Don’t think this is what would fit into the USB port of a switch and further drain away noise. Therefore looking for short USB sticks with the functionality. Having already ones from Audioquest and Ifi I am just curious to compare others too to maybe improve things even more.
Hi Ken, it was great to read your findings.I have now had the Network Acoustics TEMPUS SWITCH in my system to evaluate for over a week.
My set up:
Verizon Modem > Switch > runs of 15m to my two systems > Muon Pro Filter Systems > Server / Streamer Grimm MU1 > AES to Tambaqui.
> Eero Mesh Pro 6 and two streaming TV's wired from Verizon modem not main audio switch.
My current Switch is JCAT M12 Gold with Sean Jacobs AR6 power supply using 2m JCAT Gold LAN cables with the Telegartner screw connectors on the switch end. My long run of ethernet is the 22g Link-Up CAt 8 which bested my former Supra CAT 8
First, the Tempus is a thing of beauty. From the box, to the packaging, to the beautiful craftsmanship of both the switch and its included power supply, it screams quality.
Second, it sounds great. I let it play in for an entire week listening but not evaluating. Yesterday I spent hours comparing changes I could easily make. No, not any double blind testing. Just listening to about 6 songs, making the change, and listening again. Works for me.
I was trying to pick a clear winner, and could not. Both the M12 Gold and the Tempus sound great. But the M12 (now premier version) is just over $5000 without a power supply. The JCAT Optimo 3 duo LPS is about $1700. But I amusing a fully built Sean Jacobs DC4 AR6 power supply which is insanely good and equally expensive. I also use the JCAT gold 2m LAN cables which may add benefit as well. The Tempus, including its power supply is about $4200. I think this shows tremendous value comparatively.
I listened back and forth with each switch several times. They both truly sound great.
Next I investigated the recent info on direction of my MUON PRO Filter System. I have always had it as factory recommended. I reversed it and again listened to my batch of songs. At first, reversed sounded quite dynamic. But it did not take long to appreciate the smooth and spacious sound attributed to it inserted the original way. enough of that. I also tried removing the filter, but as always I missed it. I will say that the better you do upstream with a good switch and power supply diminish the effects of the Muon filter, but do not eliminate it.
My summary is that Rich at Network Acoustics has again designed and built a tremendous high end upgrade for streaming. Simply inserting his switch after your modem and before your streamer or server yields nice results. The Tempus is so much better than a standard switch, or the first level of upgrades I tried (EE Bonn 8) or the Etherregen.
Finally, and why not, I tried the M12 switch in front of the Tempus switch, in essence stacking switches. This was clearly the best, with soundstage expanding and speakers disappearing.
For those interested, my testing playlist: (all Qobuz streams)
Le Chat Noir, Philippe Chretien -The combo of smooth breathy sax and tight digital syncopation is amazing
Wishing Well, Buckethead - yes there is hiss here but I love the ambiance and spaciness of his guitar sounds
So Handsome Hello, Woodkid - So dynamic and gritty
Strange Fruit, Dominique Fils-Aime - She over dubs her voice several times in this song, and the better the sound the more distinct they all become, as well as distinct locations of her voices
Why Worry, Dire Straits - such a great recording
Liberty, Anette Askvik - voice, sounds, breathy sax
Chocolate chip Trip, Tool - I heard this at CAF in the CAT room in the total dark The soundstaging and movement of the music left and right, front and back is staggeringly interesting and amazing. The sounds travel well to the outside of each of my YG Haileys. Great song to remove something you think is helpful (like the switch) and listen to how the soundstage collapses.
Happy Holidays to All! Ken
