What turntables do you use? Pictures would be nice as well :-)
What's MSRP JT
I would say it will probably be in the "if you have to ask,you can't afford it" category...
I am not using anything like some of the beauties shown here, but I am enjoying my Rega P3 with the External Power Supply, Groovetracer Sub Platter, and Ortofon 2M Black Cartridge.
Reactions: Scott Naylor
MC352, I had that turntable during my naimfan period, it is great but for some reason I could not detect any differences using it with the dust cover placed or removed...
Hanss T-20TT w/Dynavector XX2mkII cart on Audiomods modified Rega tonearm. Speed controller sits atop Bel Canto phono stage in for review. Usual 'stage is a Klyne 7 v 3.5.3.
Sorry about the poor photo quality -- it's black and reflective aluminum, not a good combo for quick snap.
Killer set up Syntax
Nice to see you contributing over here
Welcome to WBF
Are you missing a table/arm there Syntax? :)
Thought the Olympos was in another arm :)
Syntax has all the onions.
My spinner...Clearaudio Master Innovation.
I have a 2nd arm (not pictured) Clearaudio Universal with a Shelter Harmony cart also mounted. The primary arm (Graham Phantom Supreme) has an Ortofon A90 cart. The tonearm cable (DIN->Rca) is a Nordost Valhalla.
rockitman-I heard your table at RMAF and it was without a doubt the best table I heard there or anywhere else for that matter. Of course it didn't hurt that it had the $15K Goldfinger cartridge mounted to the same arm you have. In fairness to Jtinn, I didn't get to hear his table working correctly at RMAF because the bearing was damaged during transit.
Thanks mep. For my next cart, I'm thinking Lyra Atlas.
