What's their efficiency at a 8.5 Khz crossover?Great site and one of the best resources on plasma tweeters. Please keep in mind that the lower the crossover point the lower the efficiency of the Acapella plasma tweeter. In order to maximize their efficiency I use them at the highest recommended crossover point of 8.5KHz.
They are 91dB over 8.5KHz. Plasma tweeters are not very efficient.What's their efficiency at a 8.5 Khz crossover?
agreed 100%... It can even be argued that having multiple tonearm cartridge combos for different flavors is simply a means of adjusting EQ. I suspect the bulk of the bad name given to equalizers (and tone controls for that matter) is due to their implementation and not the underlying concept.No need to be afraid of well designed and executed equalizers.
+1ultimately comes down to what you are trying to achieve
This likely is the conceptual goal of an audiophile whose high-end audio objective is:If the goal is replication of some mythical straight wire with gain then I agree with your premise.
This is Objective 3) "create a sound subjectively pleasing to the audiophile"if the goal is creating the most enjoyable individual listening experience
Under this view and with Objective 3) equalizers make total sense.then it can be argued that every piece in the chain is a tone control and we are all simply twiddling EQ knobs
Hello Dave,It can even be argued that having multiple tonearm cartridge combos for different flavors is simply a means of adjusting EQ.
The issue is that first there is no way for the audiophile listeners to verify or confirm the fidelity of their system to the master tapes. Even if the master tapes are at hand, verification would require measurements from end-to-end, from magnetic tape to ear, in order to authenticate.+1
"2) reproduce exactly what is on the master tape or digital file"
In essence this is what we all are doing, even those “pius” purists audiophiles, they just don’t realize it, or understand the elements at work.This is Objective 3) "create a sound subjectively pleasing to the audiophile"
Stacked 57s or a pair of 2905s or 2912s? Anyone heard both and able to comment?
I used to be an anti-eq'er and a card carrying member of the cult of straight wire with gain. Then one day I experienced a cello palette. In the flat position it did remove some of the magic of the music but once engaged and some shaping applied the net result was substantially better. My take away from this was committing the crime of using EQ was well worth the risk of scorn from fellow audiophiles.
sorry for the veer off topic and we can now return to your regularly scheduled programming.
dave
Hello Dave,
I think this doesn't recognize that tonal balance/EQ is merely one of the sonic reasons some audiophiles like having more than one cartridge/tonearm combination. Other sonic reasons include differences in dynamics and in transparency.
This becomes a very slippery slope and ultimately comes down to what you are trying to achieve. If the goal is replication of some mythical straight wire with gain then I agree with your premise. However; if the goal is creating the most enjoyable individual listening experience then it can be argued that every piece in the chain is a tone control and we are all simply twiddling EQ knobs with each and every equipment swap.
dave
No need to be afraid of well designed and executed equalizers. Crossovers, both active and passive, are fixed filters while equalizers are adjustable filters but they are both filters so if you are going to take aim at the use of equalizers you need to understand that response shaping is already taking place in the crossover. No need to fear equalizers or think of them differently than crossovers. The crossovers allowed the designers to “voice” the speakers and equalizers allow the end-user to “voice” the system in the most basic of ways. There are far more advance and effective ways to tailor the sound of a system than with an equalizer but at least equalizers are sound sculpting tools, even with their limitations.
Again my response was pro EQ if necessary not against, then apply the usual disagreement on how to do it especially with already under powered systems before one starts applying EQ boost ..
Regards
I'm sorry bonzo. I only saw the play button first time and missed the link. Reading while traveling. Thanks for the write up.it’s mentioned there, triamped and who built it
Well done amplification.Hey,
JP is fighting the registration spam-bots so until he can respond and I will handle many of the technical questions in the meantime.
The speaker cabinets are made by a craftsman in Maryland to this specific project.
In the original '57 design a single amplifier drives an input transformer that steps the signal up to feed a high impedance passive crossover which directs the music to the appropriate panels.
JP's 57's use a line level crossover integrated into a pair of push pull 300B amps loaded with step-up transformers tailored to the panel frequency response. JP has added some additional subtle crossover shaping to the panels directly. One key aspect is the dual 300B amps reside in the base of the speaker to avoid the need to step down the voltage to drive speaker cables to then step it back up to drive the panels. In a typical situation the output of a 300B will see a 25:1 step-down to get to 'traditional' speaker level. This is then stepped back up by a factor of 70 for the highs and 280 for the bass to drive the electrostatic panels. This instance has a pair of 300Bs feeding a 1:2 output transformer to drive the HF panels and a second pair feeding a 1:8 to drive the bass panels.View attachment 122529View attachment 122530
dave
Veering off a little more. Isn't that a Schiit EQ. Are they any good?agreed 100%... It can even be argued that having multiple tonearm cartridge combos for different flavors is simply a means of adjusting EQ. I suspect the bulk of the bad name given to equalizers (and tone controls for that matter) is due to their implementation and not the underlying concept.
dave
Yes, it is a Schiit EQ. I thought it improved the sound when used but was not in the same league as the Cello or Dave’s EQ.Veering off a little more. Isn't that a Schiit EQ. Are they any good?
