advice sought, turntables $10-20k
Keep in mind the motus I recommend is the II, suspended DD, which is good value for money. Also I don’t know what inflation has done to its price since 2018.
the other good value is the Feickert Firebird.
Brinkmann or AF3p etc will be better than them but you are going up in price
Fair enough. The Motus that I got, mint at a very good used price, is non-suspended. I figured I could get some isolation through a platform. But I'm sure the II is great and can see why many might prefer it.
Agree that the Feickert tables look great.
And I would've loved to have got a Stabi R. I saw one at Common Wave in LA and thought it really looked the business, but I really only buy secondhand, and the Stabi R, being newer, rarely comes up.
For the low cost you should try a ViV with the AF5.
Huh. Wild-looking arms. Will look into them.
Right now, for rolling some vintage, high-compliance MM carts, I'm looking at:
--SME Series III
--SME Series II Improved
--Denon DA-401
--SUPATRAC (9" version)
I'm not looking to blow much money on this additional arm, tbh, and I'll probably end up with either the SME II Improved or the Denon, as they have interchangeable head shells. Mostly just looking for a low cost but solid arm to have some fun with these low VTF MMs.
I'm otherwise content with the 4 Point 14 and the CB-1L as my go-to arms and the GrooveMaster and Jelcos for SPUs and DL103(R) fun.
Reactions: mtemur
I noticed a beautiful looking Stabi R Wood listed for sale on another forum for $7K.
I heard the Stabi R Wood at AXPONA last year using the Kuzma Ref 313VTA arm and I thought it sounded really nice.
I'm considering either the J Sikora Ref or the Standard Max for my next table. If I decide against spending the cash for the Sikora, I would then consider the Stabi R Wood for a great deal less money, and I think I would still be very happy.
Best wishes,
Don
--SME Series III
--Denon DA-401
ViV is not for high compliance MM but for your low compliance carts you’d likely find it better than your other arms.
I see. I took the recommendation as applying to the MM carts I mentioned.
But I see now that the damping is for high compliance. Could be interesting. I'm reasonably content with what I have for arms currently--save for a low effective mass arm--but always glad to have interesting stuff on the radar.
That’s the one huge plus of Kuzma. You can email Franc directly, even if you’ve purchased used gear, and he will always respond with great detail (usually within 24hrs). Exceptional support and his products are also very well made and engineered.
This is very definitely true, I had an issue with my motor....Franc answered emails promptly and worked closely with both me and the distributor....he ultimately offered to repair my motor at a very reasonable labor charge...
@wbass
I came to this thread late -
What cartridge are you contemplating?
I notice you seem to be using SPU's and Denon 103's largely.
I am no authority on cartridges, but perhaps you ought to factor something like a BENZ LPS into the purchase together with the arm in your budget unless you have more arms etc.
If you are considering SME then you need to also consider an Avid Acutus which has upgrade paths - I heard an Acutus against an SME 30 and whilst cut from the same cloth I thought it was more 'juicy' so to speak the SME being more dry and matter of fact. I hasten to add they were both superb.
Have you got the chance to audition any of these decks? 10-20k is serious money and you ought to enjoy the experience - do some auditions - you will no doubt receive many recommendations... I can safely assume that you are person that appreciates a deck that times very well insofar as one of ur decks is a DD and the other an idler.
Reactions: wbass
@wbass
I've added a few other carts: a Kuzma CAR-40, a SoundSmith Sussuro, and a Ortofon A90. While I recognize that there's an argument for having gone all in on one cart, I quite enjoy playing around with different combinations, and all the above were found secondhand for excellent prices. I'm sure I'll consolidate at some point, but for now I'll be enjoying tinkering. Or, at least, whenever I get all of my hifi stuff out of storage. Still working on the table. Buying property in the UK is a frustrating process, but I won't expound on that here.
That’s a fine smorgasbord of MC’s my friend. Not sure where ur based but Unique Audio, midland audio exchange and analogue seduction may have the sort of deck ur looking for
