The [coffee snobs'] espresso thread
Sorry I missed this! I've seen the Robot and some other similar devices. I assume it's very similar to the Forge, but maybe the design provides better leverage, the Forge does take a decent amount of force to achieve 9 bars. It's not too much, but I guess that's relative. I think some may find it requires too much force to easily use.
I'd expect the results to be identical as long as they can both be preheated similarly, that's the big issue with both of them vs machines with boilers. OTOH boilers take some time to heat up, some machines require 45 min to get to ideal temps, while a kettle can get boiling very quickly. With the Forge, I put it on top of the kettle w/o it's basket, it fits on a std gooseneck kettle you'd use for pourover nicely. Then I further preheat it by using a blank portafilter basket used for backflushing. I also use a stainless steel mesh cover on top of the basket so when you pour in the hot water it doesn't disturb the puck (link below).
Appreciate the detailed reply. My feeling is you are correct they both result in a highly similar output where effort has been put in.
From a glance it was hard to assign how they might differ. Other than possible injuries.
I’m not seriously thinking about re-acquiring a roaster …. yet. But I can tell that I’m on the trail that leads there.
My grinder recently failed. I had a backup of the same model, but it was a conical burr, and I’ve been thinking I would like to move up to a single dose flat burr. So, I got a unit with a third hp motor, anti static shoot, 64 mm burrs, and it weighs about 20 pounds.
The new grinder begged for a more serious machine. I don’t generally make milk drinks, so I considered a spring lever for a while, but opted instead for a single boiler/heat exchanger unit with an E61 brew head and a pid temperature controller.
It showed up this evening. As late as it was, I had to set it up and try it. I had some single origin light roast Costa Rican beans handy, I let it warm up for an hour with the bottomless portafilter and precision basket, and did some experimenting. I had a perfectly coalesced rat tail flowing on the first trial.
The first doppio was actually as good as my final doppio out of the last machine. But the extraction time for a 2.2 ratio was a bit short. Flavors were there per the expected profile, but skewed toward the darker end. So I dialed the grinder down, and pulled another doppio. The second had an extraction time in the middle of my target time window, and the flavor profile was better balanced.
And so the quest begins again. I’ve had a stable routine for 12+ years, but the new gear exceeded expectations on the second try. Is a roaster back on my agenda? I’ve enjoyed NOT roasting for a decade. But the itch is alive again. Sigh …
Espresso is like vinyl. E61 is like a great tonearm. The flat burr is like a great cartridge. PID control is like a great platter and speed controller. And beans are like a tape properly mastered by a Bob Ludwig level roast. .
Can’t wait for morning …
what power conditioner do you use in your espresso machine? will dedicated power line make a difference?
:eek::p:p:p
Good one.
Does everything make a difference?
How about something like a rhodium filter basket with micropolished holes in a special guru approved pattern?
:eek::p:p:p
Good one.
Ok, here you go:
https://caffewerks.com/products/baristapro-nanotech-by-ims-18-gram-espresso-filter-basket
Great baskets btw, especially if you have a large flat burr grinder they allow very fine grinds, but most grinders will make too many fines.
I replaced my spring lever machine with a simple full manual. I initially bought it because a good friend owns the business and a portable machine seemed interesting, but it ended up making better espresso than my machine. It holds up to the high-$ machines found in good coffee shops too.
Ok, here you go:
No doubt the basket makes a difference… the grinder really does too. If the grinder has too broad a profile on the fine end, a great basket can save it… but it can’t hide the taste.
Lots of play value. Today I have a roast that appears to be short on good flavor, but really high on buzz. It may be the potato vodka of espressos.
Regarding the Forge, I like the fact that you have so much control over the pressure profile. It’s like a modern, less complex, version of the La Pavoni line. I think the last frontier in espresso machines will be computer control of the pull’s pressure profile. It’s not just peak pressure that matters. It is both the integral and the derivative. When PID programmable pumps are offered, I’ll have to try one.
Reactions: DaveC
I got you on that too!
A friend has the Decent machine and it's really great, it'll make adjustments based on flow rate. With a full manual you can make fine adjustments based on feel and it's possible the lower temps of the Forge vs a typical machine might be a good thing. I fill the Forge with boiling water using a blank basket used for backflushing to warm it up. The Decent machine is the iPhone of espresso though, it's compelling.
Another thing to try if you have a big flat-burr is a super-lungo, around 4:1 or even longer... there are no fines to make it bitter. I have a Mahlkoenig EK43 with SSP espresso burrs and Titus carrier, it's massive overkill but a coffee roasting business was selling it for a price I couldn't refuse. I have yet to get into roasting though, someday I will...
The Decent Machine looks pretty decent. Lots of play value there. Lots of potential for unlocking bean secrets.
The whole quest is about extraction of flavor without the negative components.
As much time and money as goes into coffee beans and prep, you would think the mysteries had all been solved. But it’s not the case.
Reactions: DaveC
I love my Decent machine. Upgraded grinder this spring to Kafatek Flat Max which was a game changer. Highly recommended!
Yeah, my friend with the Decent also has a Flat Max. It's pretty similar in output to my EK43, like a home version. I agree these types of grinders are game changers, especially if you're into making espresso with a variety of beans. My grinder is worth 10x what my machine is.
I am pretty basic. Lattes mostly. I’d like to find an espresso machine which has as little plastic components as possible
It looks like the Ranchillo Silvia has a brass boiler and mostly metal lines.
Any other recommendations?
Latte lol. Milk in coffee is like heavily colouring your system.
(This is a snobs thread)
We have the Sylvia / Rocky units and they do quite well for whatever you wish. You don't have to be a 'snob' to benefit.
Our first Sylvia lasted 17 years before we gave it to our daughter and secured the larger upgraded one and it's great too.
Reactions: wil
Yes, I know and am deeply ashamed.
As you should be!
I don't think the machine makes a huge difference, but for milk drinks a double boiler gives you a boiler just for the steamer, so if budget isn't an issue, go double boiler. I'd spend more on the grinder and I'd also recommend trying a few different portafilter baskets. Some have larger or smaller holes, with traditional espresso a more restrictive basket and a courser grind in a good conical grinder will likely work out best. There's a lot of good affordable grinders that have hit the market recently I haven't kept up with, so I have no idea what to recommend.
People really like the automatic Swiss made Jura models too.
But the Silvia has a very strong following. It would please most people who want to make milk drinks.
Be sure to read the size specs on any of these machines. Many brands are quite tall, so not readily well-suited to under cabinet countertops. You can buy a countertop appliance slider to make moving it for cleaning or water filling easier.
Regarding the double boiler recommendation, it is a good one for a person who wants milk drinks… but it does add cost.
This one has an Italian name, but it’s made in China. It is modestly priced for a two boiler unit, but it is VERY large.
People like this grinder too.
Reactions: wil
Wil, good advice from the last couple of posts… I’d ask how often do you plan to use it and are you going to be making coffees for others at the same time every now and then as well.
Going the extra for a double boiler is a good investment if you’ll be doing lattes or capps most often and you want to use it to make more than one coffee sometimes.
A good grinder is the other most important investment… especially if you see yourself using this most every day in the long run.
Reactions: wil
Milk turns espresso from vinyl into an MP3 file. Readily enjoyed by folks who are marching to a different taste drummer.
Wasabi and soy … I dunno… to my palate, wasabi dominates and hides the subtleties. Soy, can highlight, but it’s also somewhat obscuring.
But to some palates, it is positive. A palate awakener. An Indian friend and I used to get lunch together fairly often. Whenever we would go to a Thai or Chinese restaurant where the menu allowed the customer to order their preferred level of spice, say 1 to 5 stars, he would ask the chef “how do you spice it for yourself?” One time the chef said that on his 1 to 5 scale, he would choose 25. My friend said “that’s what I want.”
When the meal came, and I was enjoying my very spicy level 3, my friend raved about how he’d finally gotten a restaurant meal that tasted right to him. So … different palates are like different ears and hearing. If you know what you like best, who’s to argue?
