Good morning WBF!​
I asked the same question to Vassil today thinking that an external XDMI DAC would draw less, he said no as the motherboard continues the draw...
I was thinking that in both instances the XDMI card needs to be powered but in the case of the internal DAC that would need power too while the external DAC wouldn’t.
I am running XDMI analog to analog input on my Vinnie Rossi L2i integrated. I will be comparing XDMI analog to VR DAC via USB
I do not have access to a XDMI DAC to do any power measurements.
So far though, System BPS power draw is much larger than XDMI power draw. Charging overnight very easily keeps up with XDMI power draw
Shipping Update
The heavily reduced team spent quite some over hours in the shop to assemble and test the next batch of servers.
We are getting in the groove and we see routine effects starting to develop.
Shipping battery powered equipment also has its quirks, at Taiko we now know why there is not much battery powered equipment on the market!
We barely missed the Friday courier deadline, but the following servers - that will get a good burn in over the weekend - are ready and will dispatch beginning of next week:
- 10 (silver Olympus + I/O)
- 11 (silver Olympus + I/O)
- 20 (black Olympus)
- 23 (black Olympus)
- 32 (black Olympus)
- 33 (black Olympus)
We are very excited to get the first Olympus + I/O feedback!
Thank you !
This is extremely helpful.
It's Cristal clear where we are and I can start preparing for my Olympus + IO.
Hopefully Steve is going to get his package and will share his first impressions.
Reactions: Steve Williams
Emile will have to (all though I certainly trust Vassil's Knowledge) eventually answer this. Less processing by an internal DAC, one would assume a lesser amount of power needed...
For those getting ready to experiment, anyone can do these measurements with the Taiko app (if they have the system configuration of interest)
If you unplug your Olympus, you’re in battery only. The app will show you system battery voltage and current. Multiply these and you have a power reading for the system.
It will also show you xdmi battery voltage and current. These will give power reading for xdmi
Do this in standby, system on but not playing music, and while playing music to analog/usb/xdmi DAC and you’ll get your power numbers for both the system battery and xdmi battery
I better bookmark all these helpful hints since it’ll be 3-4 months before I can actually try things out.
Reactions: Tuckia and John T
Just an idea Ray
Why don't you do it if you find a little time for this AND share it here ?
I really like very smart and clever ideas people have here and share with WBF community.
I intend to ;) there will be a lot of permutations here I can’t test but I can get most of them. The power profile and battery power of this machine is a really big deal
Reactions: Kris and Armsan
A couple questions please.
Is having the IO directly under the Olympus going to produce marks on the top of the IO over time ?
Does the distance of the connection between the two unit have a effectiveness limitation? if say I wanted to place the IO 3/4 or 1 meter below the Olympus location on a lower rack shelf?
Hi Richard,
I'm in a similar situation: I'm going to stack the Olympus on top of the Olympus I/O.
To avoid marking the I/O I'm planning to tinker some pads to place under the feet of the Olympus. Probably a felt and leather sandwich (4mm).
Stacking the two devices may not be optimal, but it's certainly negligible compared to other parameters such as room acoustics and power management.
And stacking the two devices will avoid the need for an overly imposing rack.
As far as the distance between the devices is concerned, I think the limit will be the maximum length of the QSFP cable.
The length of the QSFP cable supplied is not specified in the Olympus manual, at least I haven't found it (@Christiaan Punter )
Cheers,
Thomas
Both Olympus units have Nylon footers which is a relatively gentle material. When stacked carefully and not sliding the unit(s) sideways after placement, the footers should not damage the surface of the Olympus units. However, the server is very heavy, and it if you want to be 100 certain to avoid scuffs, we recommend providing individual support for each unit.
Maximum QSFP cable length is 3 meters. 1 meter is standard.
Hi @Christiaan Punter ,
I plan to glue felt or leather discs (or a sandwich of both) under each foot of the Olympus Server before placing it on the I/O.
Which material would you choose? Felt, leather, chamois leather, alcantara (or equivalent), other... ?
As I'll be stacking the two machines, a shorter QSFP cable would be more practical.
Is it possible to use a 50 cm cable? Or is it too short?
Cheers,
Thomas
Reactions: pkaemmerer
I will check but I'm pretty sure 1 meter will hit the right spot on my rack if I decide to place the IO lower by itself
Thanks for the information.
I would really like to see a rearview photo of the Olympus and IO with analogue out with all the connections in the photo.
If there is one I have not seen it.
