CTH-8550 mk1 vs mk2
audio42
28
42
20
Canada
Hello,
Just wondering if anyone has directly compared the mk1 vs mk2 versions of the CTH-8550.
The mk2, even used, is quite a bit more than a used mk1 so I'm trying to decide if I should get the mk1 now or just wait for a used mk2 at a good price.
I'm also looking at a Grandinote Shinai, which is half the price of the mk1, but it's 12 years old.
Thank you,
Arun
Hello! Not sure if this can really help but having used the 2 versions of the DartZeel integrated they share the same beautiful sound DNA (mediums / highs) with a bit more drive for the MK2. Nevertheless drive is clearly not their strength (both of them) so it will really depend on your speakers...
Thank you, that is helpful. Speakers are fairly easy to drive, 94 sensitivity and 8 ohms.
Reactions: Stef
