Hello Jackelsson,
Reading your reply again, you mention that you listened to the mighty ML 811K1 in Munich. Assuming the listener has sufficient listening distance (3 m), did you find it to be in another league in terms of musicality compared to the 901 (or the ATC 150)? Thks.
Well, I think it’s important to understand that in regard to their radiation pattern and directivity Geithain builds each speaker model for a specific scenario. If one decides to go Geithain it’s really a good idea to have a look at the specified listening distances for their speakers first.
The RL901K works very well at a distance of 2-4 metres. But I also tried both shorter and longer listening distances, and while this was still fine, the 901s didn’t reach full perfomance.
Now, the ML 811K1 is specifically designed as a main monitor for larger listening distances and higher volumes. In Munich they played in a very large room with the audience at least 4m or further away. This was a situation they are designed for. With a home audio scenario with a listening distance of only 3 metres, I’m not so sure.
