I use the balanced outputs out of my IO into my ARC Ref10 SE. I must admit that my balanced cables (Tara Labs Evolution) are a much better set of cables compared with my single-ended (Cardas Cross) and thus provide an advantage to balanced. Most notable, the balanced outputs provide greater dynamics, transparency and density that the single-ended can not match.
If I remember correctly when I purchased the IO I was led to believe that balanced was the way to go. It was someone at Aesthetix but I can not recall who.
I use XLR cables from Io to Callisto. Since I don’t have 2 identical sets of cables with XLR and RCA, I have never compared the two input/output. I can’t recall why, but I am under the impression that Jim White prefers the XLRs.
I use both, obviously XlR mad RCA have different characteristics. XLR has higher gain but the Io has tons of gain. Since you have a great preamp I would look at which input is preferred on the VTL. Tubes may make a difference. The audiogon link below has feedback on RCA vs XLR. I would lean to XLR from the Io to the VTL and I would go with Cardas Clear Beyond. I know you will listen and make your own choice.
Hi,I have question regarding my Aesthetix Io sig phono stage output, I would like to try RCA instead balance connection to my preamp (ARC Ref2 mkII) but...
get the same cable xlr twice, rca do volume equalization. I think with short cables the xlr will have no advantage, only with longer cables because of better noise reduction. because most devices do not have a complete symmetrical signal routing internally.
