That is great company the Io is keepin
@ShawnZH !
I seriously thought about the Soulution 755 after a brief listen to it. I have never managed to hear the FM, however, that is on my wish list as well.
How would you describe the character of the Io against these two formidable SS phono stages?
Hi Kcin,
The Io is just with me for a few days and I'm still exploring the sound of Io. My first impression about Io, compared to the other 2 would be:
Io is the most authentic, robust and full-bodied phono among the 3, with a good balance from tremble to bass, projecting a vast sound stage, very impactful, natural and warm-sounded as tube phono should be. It is a phono for big systems, giving a full spectrum sound.
Soulution 755 is also a very fine phono, with a bit dark tone and bottom-up sound charactoer (Valin's comment from Stereophile). I feel the high frequency is not as airy and opened-up as Io. But it has its own signature of sound. When you listend to 755, you don't feel there's anything missing. 755 is also a phono for big systems, with its very high density sound, clean and fast.
FM Acoustics 222 MK3 is a typical FM sound in its own league. It is very different form any phonos that I owned and heard. It has speed, slam, details and a taste of FM sound characteristics. I feel it a bit more transparent than the other 2, also with a touch of musicality of an FM sound. Among all my phonos, the Dartzeel phono is the closest to FM, thought still not the same.
Regarding the gain Io outperforms the other 2. I use it at 74db (not the highest 80db) to drive Anna D with 0.2mv output. The gain is enough. Though 755 is rated 83db, but I feel it is quite over rated. I use 78db of the 755 to drive Annd D, it is not enough gain in my system. The Dartzeel phono is also pretty sufficent gain.
FM Acoustics 222 is with the lowest gain of 62db at its highest. I feel FM 222 would go best with FM preamps such as FM 266, FM 268 which has a high gain. The synergy of a full FM set is obvious. Plus that the balance output of FM is reversed to many, with its 2nd pin in cold. Therefore if you cannot switch the pin 2 and pin 3, it doesn't work very well with many preamps. A reversed 2/3 pin will make the sound powerless and hollow, making the lower output even weaker in sound.
