Hi OGH,
Thank you. The Io is connected to the Jubilee preamp directly. The Opus 1 was icing on the cake so to speak. The Atlas is no slouch either. Have you tried various loading options with Io direct connection to amps versus through the Einstein and then amps and made comparisons in sound. Oh yes, you did, I see your reports from above…but did you play around with loading? I am not sure if it makes a difference, but in this hobby, experimenting seems to be the norm in order to achieve the best results.
