We are going to have to agree to disagree.
There is no agreeing to disagree on this one. You are simply wrong.
there are tons of amps that have no problems with a load, the problem is to find the one that corresponds to your ideal sound with speakers
I was talking about what constitutes snarky and obnoxious not politics.I respect your opinion. But WBF simply is not the place for politics or for political innuendo.
Absolutely priceless.There is no agreeing to disagree on this one. You are simply wrong.
Why does an amplifier have to cost $ 200,000? There are used amps under $ 20,000 that are better than some for $ 200,000How does one go about doing that? Trial and error with $200,000.00 amplifiers.
I can see your point, but I'm not clear how it applies to a music system, which operates more like an ecosystem than a controlled setting. From my perspective, for whatever that's worth, I'm not in the business of comparing amplifiers in a controlled setting. My clients hire me to configure and set up their existing audio systems. Sometimes that means coming back to a system I've already set up to integrate a new component into that system. I am not there to compare one component to another, just to integrate their new component(s). That invariably requires some degree of position or attitude change in the loudspeakers. Please do not take my comment as trolling for business. I merely wanted to illustrate my point.
Well Ron, you'll soon lose all your British contingent, we're innoculated w sarcasm at birth.Please re-read my post. I did not write that sarcasm per se violates the Terms of Service.
That is fine. Again, sarcasm per se is not a problem.Well Ron, you'll soon lose all your British contingent, we're innoculated w sarcasm at birth.
Thank you. That sounds like a very sensible explanation to me.Almost any competently designed solid-state amp will have pretty much a ruler-flat frequency response from at least 20Hz to 20kHz - on a test bench, driving a resistive load.
The real world is different and a much more scary place for an amplifier—the impedance of actual loudspeakers changes with changing frequencies, sometimes with astonishing speed and degree. The Alexx V and XVX are particular cases in point, each with very low minimum impedance points.
This means that not only will an amplifier’s output capability vary with frequency, but once you start driving it with a musical signal, its capability in responding to the dynamics of music comes very much into play. That’s a critical part of this, as no two amplifiers will be the same in that regard.
So, in the real world and real systems, two different amplifiers will drive the same speaker very differently, with a different dynamic and bass response.
I think the whole point of Roy Gregory’s post was that while it would be nice if changing an amplifier were a simple thing, it’s just not. In reality, you are changing both the relationship between the amplifier and speaker but also the relationship between the speaker and the room. If a speaker is being driven differently by whatever amplifier, then the speaker will drive differently what it is driving. And that is the room. It’s been my experience that it’s essential to consider speaker placement when you change the amp(s) - or pretty much anything else in the system! That’s just physics...
Are you using a Model One or Model Two?Catching up late on this thread... Using the 108 on Alexx V right now, and as long as it's in "low impedance mode", it's absolutely fantastic.
If using the 108 in the standard mode, indeed the 108 would show some frequency response aberrations (ie: sound thin).
Gregory’s point was you have to relocate the speakers when switching out amps in order to correctly re evaluate. Hence he was denying you could swap out components to make an evaluation on the latter.Almost any competently designed solid-state amp will have pretty much a ruler-flat frequency response from at least 20Hz to 20kHz - on a test bench, driving a resistive load.
Well, I guess we see things differently. I just never thought that science was that simple. Thanks for the discussion though!Your coming at this from a vocational perspective where I approach things from a science, technology and engineering perspective. This is pretty cut and dry, if a customer wants to compare two amplifiers, repositioning the speakers invalidates any comparison.
I know that many acousticians are trained ears and not engineers or physicists but I think that when most of us are evaluating amplifiers it is typically a one-for-one swap, as it should be, and not a system retuning effort; as that invalidates the comparison. Pretty simple and straight forward.
Man your just wrong way wrong too.Your coming at this from a vocational perspective where I approach things from a science, technology and engineering perspective. This is pretty cut and dry, if a customer wants to compare two amplifiers, repositioning the speakers invalidates any comparison.
Not only more accomplished. Less baggage less BS and certainly less ahem… ‘corruptible’… oh and more actual hands on evaluation / experiences per individual component.The admin does seem enamored with posts by reviewers, advertisers and manufacturers while failing to realize that some of the regular posters on here are more accomplished.
if you don’t make adjustments your not making a correct observation. you can do as you wish of course but it’s wrong.
I have tried a few amps in my system they all sound different. but once you Adjust things whats left is the real change taking place.
I deliberately don’t post my system set up or my perceived affiliations. Best not to get into playing ‘his system is…’ bollox.The admin does seem enamored with posts by reviewers, advertisers and manufacturers while failing to realize that some of the regular posters on here are more accomplished.
I want to agree with you. I often do. But here. Nope. No can do. Sorry.Man your just wrong way wrong too.
