Roy, I enjoy your writing and thanks for your thoughtful comments, however I regret I must disagree with much of your opinion. It takes no more than switching out the JL Gothams to hear the sluggish bass response of the M10 driving the Alexx V full range with anything less than 20% feedback (which I found unacceptable for the mids/highs). With the JC1+, the Soulutions, or the Mephistos, on the range where the bass overlaps, it is easy to hear the Alexx V and Gothams are entirely temporally aligned. With the M10, they were not. Furthermore, no phase adjustment on the Gothams was able to get them in synch. Simply put, the performance of the Soulution, JC1+ and Mephisto, driving the Alexx V alone (as well as with their excellent integration when driving the Alexx V w the Gotham v2s) further suggest it is indeed the M10 as the lone unit that delivered unsatisfactory bass performance with the Alexx V. That's 3 amplifiers which performed beautifully in delivering the high quality bass that I believe is a performance strength of the Alexx V. The M10 simply did not. You suggest that changing an amp will change the bass and character of a speaker's output. I totally agree it might. But why does it seem so difficult to appreciate that CH themselves state clearly in their manual that one should increase the feedback if you want more "grip"? This is basically an admission of a dampjng factor deficiency that must be altered with feedback to deliver satisfactory bass under select conditions which can easily be a certain speaker, particularly one with a difficult load impedance. One need not resort to other nefarious explanations such as speaker wire, the cycle of the moon, or speaker position to explain what I am hearing, In fact, speaker position is critical, but that will effect frequency response predominantly. What I am experiencing is not a quantitative difference in frequency response but a qualitative one and a dramatic one at that. It's a disconnect in the temporal domain with the rest of the range that the M10 does so well in everything save the bass. There is also a discernable sluggishness in comparison to what the bass delivers from the Gothams, which is a useful comparator. Believe me, I wish it wasn't so. I adored the midrange, top end, and dynamics of the M10. But the bass? Painfully disappointing (with 14% feedback which is highest I could bring myself to use) in comparison to the other amps mentioned. Again, this is my conclusion and when 3 fine amps deliver the goods and one does not, under identical circumstances it's the amp until proven otherwise. BTW, I believe disappointed is a far better term than confused here, and of course YMMV. If I am correct, I believe you did not use the M10s with the Alexx V. When you do, let's chat and see if we are in agreement. You may hook up the M10s and move the Alexx V around the room all you wish and let me know what you find. Then play them with the JC1+ (at 1/10th the price of the M10), move the speakers anywhere you want and then, let's chat. As we say in the lab, first do the experiment!
