Of course they aren't ten times better. Maggies are OK value. Law of diminishing dooberies etc.
If you want the best planar magnetics on the planet, the Alsyvox are probably it.
They have faults, though. You need to be along way away for the bass from the bass panels to really blend with the 4 way mains. So even this speaker system has integration issues of sorts.
They may have longevity issues I simply don't know, but it is a risk.
It's a one man band not a big company etc.
All sorts of factors need to be considered I think much as I love the sound they produce.
When I retire I think my hobby will be trying to make a Diva or Boticelli sized pair of planar magnetics from scratch entirely by myself using my own ideas just to keep me from dying of boredom. I think it is quite doable. I really do.
I will not stop until they are outstanding. Then I'll drop dead with peace of mind![]()
If there’s bass integration issues with the Caravaggios I do wonder if having four panel ribbon panels are then ultimately just too hard to absolutely integrate and completely dial in... with large panels the very slightest lack of coherency and integration is just so easy to hear.
Even just just a few millimetre moves when dialling in ribbons are the difference between seamlessness and disconnect and achieving absolute coherency is really the full range ribbon panels greatest accomplishment.
Maybe this could then be an archille’s heel in multi panel models like the Caravaggio and Maggie 30.7s. If there is any sort of bass integration issue in the Caravaggio this would be a definite $300k deal breaker. It’s a deal breaker even at $30k.
Maybe the simpler two panel full range ribbon models have an advantage in this.
