Tim,
Semantically, I can agree with your point: a design in which a "tweak" (such as a PS upgrade) induces a sonic improvement, relies on a faulty (or compromised) design.
But in a practical world I do not agree.
Almost all the audio brands we love or hate have a selection of lines of gear. Some of them have it wide (Naim, Focal, B&W, Audio Research, Burmester), some other limited (VTL, Spectral, Mark Levinson), some almost have no line separation (Convergent, DartZeel).
According to your point, every brand that produces more than one line of products should have a well made one (the reference) and a series of faulty ones.
But it is clear that the less expensive designs HAVE TO have some compromises compared to the reference lines.
The fact that PS is touched here may create more doubts in you, and I can get it. Notwithstanding, the PS of a ARC LS-17 is definitely modest when compared to the one of a Ref5. Is the LS-17 a bad designed product? Or are the design compromises due to a price tag goal? Would it perform better if fed by a more generous PS?
But, AFAIK, in the case of Naim the addition of external PS in usually mandatory, and can vary according to the system design. Most of their preamps, for example, do not incorporate an internal PS: either you slave them to the PS of a power amp or you get a dedicated PS. Then, if you were concerned about the differences between the various PSs, well, I don't know, probably the differences might tend to zero once you provide just the right power needed.
