Not sure how she sells any of this as it is not listed on her site, the ground boxes ect..I’ve posted extensively about my positive impressions of the changes/improvements that Holostages make. Yes, I’m the one who described their effect as “swimming in music”. Some of you scoffed & that’s ok, but a number of you thought the analogy was spot-on.
I must have 4 sets of holostages tucked away in various places. They create such an immersive experience that the center image sometimes strays of course, so by placing 2 holos between the speakers (I had been placing them on top of each speaker) I find the center image snaps back into focus while retaining the immersive tall, wide & deeply layered soundstage.
The others are placed on top of or under power supplies & NA tempus switch, muon pro & eno2 filters, behind the listening position on either side, on top of & underneath Verizon FIOS modem (surprisingly restored full Wi-Fi service to several dead zones in the house) & on top of bi-wired speaker posts.
Half the fun is moving them around until you find the perfect configuration for your room & kit. The impact the holostages make is so easily heard, that the addition of only 1 set of will surprise you!
I have also integrated Krissy’s ground box booster to the chassis of my integrated, her usb box to the input of the integrated as well as her breaker panel box transforming the acoustics of the room while dramatically lowering the noise floor.
Highly recommended!
If I read you right, you do not recommend placing on your components? Second, is your router and switch next to your audio components or in another room?Tried in two more rooms today. It also works with two in the corner of the front wall and two half way between speakers and listening position. Also we experimented with different heights between 1 meter and 3 meters. We always found the optimal position to be around 2.20 meters. Above the soundstage gets unnaturally high and the sound looses body. If placed too low (approximately below 1.80 meters) the soundstage is too flat and the music gets too dull. But once the room „locks in“, it is absolutely incredible how much bigger the soundstage gets and how the sound fills the entire room. It really transforms the experience from looking at a painting in front of you to being fully surrounded by it.
Yes, that’s how it behaved in the four rooms. I have router and switch in the same room and off axis from the four Holostages. Switch is even on the floor. Any holostage lying around on the floor kills treble energy. We accidentally forgot a box of 4 Holostages on the floor. It was almost ridiculous how much it killed high frequencies.If I read you right, you do not recommend placing on your components? Second, is your router and switch next to your audio components or in another room?
I have my router and switch in a media closet in a totally different room. I wonder how that would impact the sound?
I just got mine and wired it straight to the binding post on my Shunyata power conditioner.Some advice please.
If I had to select 1 spot to try out the ground box booster, where would you recommend I place it......and exactly how should I safely connect it?
I have a Puritan 156 power conditioner connected to a Puritan City Master for example. I also have a Puritan Route Master connected to all my components, and the Route Master is connected to a Puritan City Master.
Or perhaps start with a simple chassis screw on my preamp?
I only have a "spade to spade" Audience Front Row ground wire for my test, I need to get a few more ground wires.
Thanks for the advice.
I’d leave the Puritan City Master hooked up too — but I’d try with and without. I’ve got a Puritan Ground Master and was surprised to find it sounds better without it.Halydean and Miller,
Thank you both for getting back to me.
Halydean....when I connect the Ground Box Booster to my Puritan 156 as you suggested, should I leave the Puritan City Master connected to the 156 as well, or take that off and just use Krissy's Ground Box?
Miller, thank you for the additional feedback on the Holo's. I received 2 of those and placed them on the output transformers of my 300B mono amplifiers based on a suggestion I read in this forum. Since I only have 2 Holo's (so far) would you recommend trying to place them somewhere else?
I must confess, I was (am) a big fan of Tim's and Krissy's stuff. I still have my total contact in the freezer.
Funny story.....my friend's wife accidentally threw out a syringe of total contact when she was cleaning out the freezer. I swear I thought they were going to get a divorce!
I should add that it is probably not due to the Puritan Ground Master— but due to my ground. My guess as to why it sounds better without it is because my main household ground must have a charge to it or a lot of noise, which is a problem that needs to be fixed.Interesting. Thanks for the feedback. I'll try it both ways. Figured I'd better ask before damaging anything.
