Just got my unit. i am setting things up but I see that I can’t set up Chroma to be 4:4:4. What would cause that?
My processor is a Lyngdorf MP60 2.1.
Hmmm.. Which display do you have ? That is a tad odd. Your processor should support 4:4:4. Not that any material is in 4:4:4.. The latest Sony OLEDs support 4:4:4.. Just copper wire hooking it all up right ? No little boxes or HDMI extenders ?
Again. Not that it matters, but its curious.
I have a Sony VW675ES projector. Only wires between the Apple TV X and Lyngdorf and Lyngdorf and projector.
The spec sheets do not cover what color formats the proj supports. So this is most likely a projector "limitation".. But NOT one to care about as there is no 4:4:4 content. That is why it does not support it.
The brightness and contrast ratio make it a SDR display, just like a Sony 380, or any projector I know of. So for sure stick to 4K SDR.
Have fun.. With your surround processor and audio system, the sound will be really fun..
You will have 3 points of burn-in.. First is 24hrs. It will clearly be better.. Then about 2 weeks and then about 1 month.. Make sure to set "sleep > Never".. It should stay on 24/7...
You're gonna love it!Thanks. I applied all the recommended settings.
Wow, very cool!And then the upgrades start... Power cords, ethernet cables, feet, mass loading, grounding, HDMI cables.. I have had people upgrade displays, surround processors, interconnects, even center channel...
This client made a cool isolated stand.. I know... I know.. We all want one.. He is considering itI wish i was handy like this with tools.
I see the video improvement with a direct connection between my television and the Vanity Pro. I use the most current Apple Tv as my source. I believe the designer of the AppletvX didn't see any improvement by adding linear supplies to other devices. Do you have an Appletv? The other possibility is that my video switching is not as transparent as the direct connection. The AppletvX is a much more extensive modification by someone acutely aware of video quality.My previous, cheap, hmdi audio extractor did not pass HDR10 or 4:2:2, but Vanity pro does, so there was an improvement in the video. However, in my system, the Kaleidescape video is better.
Hi Chris.I had a Switch X Client call me and ask a technical question. He had the Switch X hooked directly to a Arris S33 modem and then to his audio gear. It was a mistake, he forgot here needed a router for the rest of the house. BUT his hook up was pretty hardcore and direct. Just the Switch X ( which does NAT so works like a router ) and his high end audio gear.
I got him straighen out getting his house router after the S33 and before the Switch X.
BUT.. He reported a drop in audio quality for his streaming.
Interesting...
Of course having a dedicated modem JUST for audio is expensive as it requires a 2nd account from the cable or fiber company. In fact Comcast wont do it at all in one house. But his experence got my attention because he described a clear difference in audio quality.
So here at my place I have AT&T fiber and I have Comcast. So I have a S33 modem AND I have a FTTH fiber modem. I feed my lab with the Fiber. In fact it hooks to my own Switch X and the Switch X feeds my computer and my ATVX..
So I just did a AB... I hooked my Switch X to the house network that is powered by Comcast and a $3000 Mikrotik router. Then moved back to a direct connection with just the fiber modem.. INDEED the pic/sound did improve !.. I just flipped back and forth with and without a router in-between and YEP direct is better.
SO... While its kinda crazy, a 2nd account and a modem dedicated to your audio / ATVX is a better way to go..
I found this interesting because its pretty much impossible to explain technically.
SO.. Watch what all is in-line in your network between the outside world and the ATVX apparently it DOES matter.
I have an Appletv X.I see the video improvement with a direct connection between my television and the Vanity Pro. I use the most current Apple Tv as my source. I believe the designer of the AppletvX didn't see any improvement by adding linear supplies to other devices. Do you have an Appletv? The other possibility is that my video switching is not as transparent as the direct connection. The AppletvX is a much more extensive modification by someone acutely aware of video quality.
My wife first confirmed what I was seeing. I had not said anything as I figured she would not be interested. As she was walking by, she paused to view the picture and remarked that the picture was great.
SwitchX for ALL!!A quick few notes. I will come back later this evening and reply to the other posts.
The Apple event did not discuss a new ATV.
There was a announcement a while back about Netflix discontinued support for the 3rd gen ATV. This refers to a ATV from 10+ years ago and was barely HD. This is pretty good support going back 10 years.. So we may well get 7+ more years out of the A2169 which the ATVX is based on
TVOS 18.0 has some significant improvements coming that apply to the ATVX. I am a Apple Developer and I am running TVOS 18.0 now on 2 ATVXs. So far so good. DO NOT TRY THIS AT HOME, A beta could brick a ATV and I can't bring it back and there is no way to back up in firmware. So Betas should never be used unless there is a need that outweighs the risk. I will test 18 and by the time its out of beta I will post a all clear.
Updates to the Home experience elevate entertainment and bring more convenience
Apple today announced software updates across its Home products that supercharge entertainment and deliver greater everyday convenience.www.apple.com
I sent off a bunch of Switch Xs to reviewers today. One has had a ATVX for nearly 2 years and he will try out the Switch X with the ATVX. Formal reviews tho take time to publication.
Yes... Might cause back log.SwitchX for ALL!!![]()
While I am happy with my SwitchX, we are downsizing and my 2-channel rig (see my signature) , which includes the switch, has gotta go.
So, if you've been thinking about getting a SwitchX (with WiFi-X), DM me and maybe we can help each other out. I'll be posting it for sale sometime this week. Thanks.
ChrisG
Hi Chris.
Maybe I'm misunderstanding you, but are you saying it's preferable to use your switch X as a router, rather than as a switch?
So Arris S33 modem=>Switch X as router=>no switch.
Instead of Arris S33 modem=>a router=>switch X?
If yes, what about to use Aris S33 modem=>Switch X as router=>Switch X as switch?
I know it isn’t so directly as without a switch, but maybe there will be a synergy effect?
I have to put these
in my apple tv 4K, but I have problems to find a Wima PP 4.7uF, if it’s length should be < as 10mm, as in Your picture above.
Do You still use 4.7uF wima’s?
