Aqua LinQ
Anyone has experience with the new LinQ network player?
FEATURES
• Proprietary fully-floating hybrid 2-stage Network + FPGA module with proprietary code
• Uncompromising digital interface AQlink PRO (I2S protocol)
• 4 future-proof network protocols (modules). Available now: Roon Ready bridge (RAAT) and UPnP DLNA
• 2 separate low noise C-Core power transformers for network circuitry and digital decoding
• MODULAR DESIGN with upgradeable multi board platform
• High-quality parts
• Input:
n. 1 standard RJ-45 connector for the ETHERNET network
No network configuration is required (DHCP system).
• Outputs:
n. 1 Ethercon RJ-45 connector for the AQlink I2S signal
n. 2 XLR 110 ohm connectors for the dual-AES/EBU signal (PCM 24 bit 384kHz / DSD128 max)
n. 1 XLR 110 ohm connector for the AES/EBU signal (PCM 24 bit 192kHz / DSD64 max)
n. 1 BNC 75 ohm connector for the S/PDIF signal (PCM 24 bit 192kHz max)
n. 1 RCA connector for the S/PDIF (IEC-60958) signal (PCM 24 bit 192kHz max)
• OLED display with user off-selectable illumination
• RC5 IR remote controller (optional)
• Aluminium anti-resonant cabinet with Nextel
I wonder if anyone has tried connecting the Aqua LinQ to any dCS DAC using Dual AES with 24/384 data stream?
Do they have the same data format and compatible or not?
Reactions: jasond
