4. Mixing and matching of other audio components after Choosing power amplifier and Speaker
when you choose your room and speaker and amplifier then you can go for Pre amplifier and DAC and Transport and Turntable and phonostage and ...
4.1 all voltage ranges should be match , for example the maximum output voltage of dac should not be higher than maximum input voltage of pre-amplifier. Some dacs like MSB and CEC and dCS has output voltage of 6-7 volts (XlR output) .
4.2 the ideal condition of voltage transfer between component A to component B is the input impedance of B should be 1000 times more than output impedance of A. Many tube dacs can not perfectly drive low input impedance of SS pre-amps. We should care about perfect Impedance matching of components in the chain.
4.3 ground loops and earth connection type of components and chassis voltage of different components and AC polarity of components should be considered.
Some electronics have floated ground and most systems have not floated ground, some systems are fully balanced and some systems are not fully balanced , connecting different components with different designs may degrade the sound because of some mismatch .
4.4 every component has his own sound and connecting very different sounding components may cause mismatch in sound. I do not use tube dacs and tube pre amplifier in a fullrange SS system.
All you hear about adding tube preamplifier to soften the sound is awful solution and they try to compensate an error with another wrong decision. Many wrong judgments in audio reviews come from mismatch problems. Stereophile and TAS and most magazines do not care about this and only put the device on the chain and start to review.
