First serious review: https://gy8.eu/blog/take-two/
hope to hear it soon
Compared to the new one, this one looks from the stone age. If you want imposing, check out the new oneI kind of miss the old version which was quite imposing in real life. Everything must change.
Avantgarde speakers never sound their best at audio shows.I thought the sounded good at AXPONA. In fact, I think the Duo sounded better this year in that room than the Trio's did last year. Maybe turning the system 90 degrees was a good thing.
What's the news on your audition?I am going to hear the iTron Duo GT this month. Will keep you posted.
BTW, I think other manufacturers are crying and laughing at the same time. Crying because they know they cannot beat the iTron/Avantgarde sound quality. Laughing because they know that sound quality is second to prejudices within the audiophile community. Some are shouting I HEAR HORN COLORIZATION before the first note has been played, others won’t accept that their ueber power amp is trumped.
Mezzo it will be . Trumped the GTs in every way (how incredulous this may sound)What's the news on your audition?
Interesting. Could you describe why the Mezzo should sound so much better than the Duo, and have you auditioned both under similar circumstances?Mezzo it will be . Trumped the GTs in every way (how incredulous this may sound)
Hi there, the attachment says it all really. But some key points. The Mezzo goes much deeper, the integration between high/middle and the bass is much (!) smoother. I will go for the non-iTron because I have an opportunity to get those. I simply LOVE the way they look. I hesitated answering you when you use “spoil my view” when talking about the GTs…. The Mezzos are built better than the GTs. I have not heard both models in the same room. The iTron is apparently a newer generation than the GTs if you go that way. The 207’s are going to leave me after 12 years. Still marvelous loudspeakers.Interesting. Could you describe why the Mezzo should sound so much better than the Duo, and have you auditioned both under similar circumstances?
The mid and top horns and drivers and the iTRON amp elements are identical as far as I can establish, and the bass section has identical drivers and amp / DSP in both.
The only differences as far as I can see:
1. The length of the mid tube may be 1" / 2.5 cm deeper with the Mezzo, but that's only based on the Mezzo total depth of 72 cms, compared with 69.5 cm for the GT - per AG specs.
2. The larger bass enclosure and the flared exit from the bass drivers - not quite a horn but it may offer some horn advantage compared with the more convention flat-fronted sub of the Duo. Oh, and the Mezzo has twin reflex tubes if that is relevant.
I ask because I'm inclined to favour the Duo GT as it is much "slimmer" than the Mezzo and would spoil my views to a much lesser extent. In fact, I've slimmed down my existing Duo XDs by replacing the "scaffolding" supports with a top-mounted bracket for the mid-horns as per Mezzo. The Duo GT is possibly influenced by my own mods as they were favourably commented on by Holger and Armin!
Thanks
PS - I note you currently use KEF Reference 207/2s - I used to have their Reference 107s. Will you be upgrading to Mezzos?
PPS - This is what AG claims are the differences between the new Mezzo and the new Duo GT -
It's the Mezzos that would spoil my view because my speakers are placed mid-room with floor-to-ceiling glazing beyond.
3 or 4 years ago I was considering a change from my original Unos to electrostatics. I bought a pair of used Quad 2905s to see how they sounded, knowing they couldn't stay for long. They sounded good and this prompted the purchase of more visually acceptable Martin Logan 13As, but sadly they didn't like my room so had to go. I kept the better-sounding Unos, soon to be changed for Duos and now Duo XDs. This photo should explain why I don't want "fat" speakers such as Quads or Mezzos! These are my XDs with their non-standard mid-tube supports in place of the scaffolding that added unnecessarily to their corpulence!
good questionsThat said , do you not find that your music playback tends toward the ‘brighter’ end of the spectrum , in the auditory sense rather than the optical . You appear to have quite a lot of fairly hard reflective surfaces comprising the structure of your room with little in the way of softer surfaces or objects to counter balance the former . How do you fair with simple sonics tests such as hand clap or vocal for reflection and reverb ?
Thanks. When I first moved to this new-build flat, the acoustics were dire, in particular the reverberation you have mentioned. However, adding carpeting to 2 large areas (about 35% of floor area), more soft furnishings and hanging curtains (that are very rarely closed) has pretty much tamed the problems and there is no false brightness or reverberation. One advantage I have is that, with no parallel walls, there is very little reflected sound and horns are probably the best type of speaker to mitigate these problems. I have experimented with Dirac Live filters to take care of room anomalies, but I prefer the sound with No Filter.What a lovely space , light , airy , especially on a clear day as in that particular photograph , I can feel my serotonin levels rising from merely looking at it :0
