congrats!
Thanks Lloyd, I've been listening the system since 5 AM today, this amps deliver a very credible soundstage and midrange purity, there was some extra content in my records that were like hidden in some way.
congrats!
I placed a pair of Harmonix wooden footers at each amp, and bass reproduction is now more tight and fast, mids are cleaner and highs just remained the same - I have had this footers for quite a long time but it is under this setup that showed their benefits the most.
http://www.combak.net/feet&bases/FEET_and_BASES.html
I have once tried two Jadis amps in my system - JA-80 Anniversary with the matching JP-80 Anniversary pre (...) ]
I have once tried two Jadis amps in my system - JA-80 Anniversary with the matching JP-80 Anniversary pre and JP-120. Two great, but also slightly different sounding amps (the KT-120 equipped JA-120 beeing more transparent and less 'Jadis like'). Unfortunately, none of them had enough grunt to drive the punishing load of Sasha.
JA-120:
JA-80:
Re Jadis amps, our local distributor then advised us users to remove the protective grills while listening, that is, if no children or pets roam around the amp area during the listening session. The grills run really hot on my JA 200s and removing them kinda dissipates the heat from the tubes more rather than soaking it all up in the cage. What surprised me was that the sound became more open, and more at ease without the grills. A few friends who did that reported sonic improvements too. But of course, to those with small kids and pets, that is not really an option. I have removed the cage from the JPL line stage and also the metal plate on my ARC amp too.
You were right Jadis!..and the improvement is not subtle! Thanks...![]()
One other thing (and based on the results obtained today...) do tube-ring-dampers work? - I have never tried them....
personally, i have to split hairs to find some improvements with these rings. but since arc supply them for free, i let them stay. but in my old arc amp, the rubber rings kinda melted and hardened into the tubes. since then, they have changed from the white rings into black rubber rings.
