Bespoke Audio TVC Passive Preamp - An Unassuming Star
Hello Stereophonic,
Have you auditioned a Bespoke in details?
If not, please do so and your view may have some changes.
Bespoke is diff and much more musical than most other passive preamps.
Yes, I have a Goebel xlr ic between preamp & poweramp.
My Vertere HB xlr is for digital to preamp.
IMHO Vertere is never voiced to be analytical, unlike brands such as Nordost ...etc.
I guess you and me have quite diff tastes.
But of course this is not a problem.
I embrace diversity and fully agree that beauty is in the eyes of the beholder.
Thanks for yor answer CK.
I’m glad you are enjoying your Bespoke preamp. I never have listened it.
I like very much the passive preamp concept but my Ypsilon experience wasn’t successful. After listening Ypsilon, AR, Dag Momentum pre.... i’m very happy with my TAD C600.
I think cable matching is the key.
I have to rectified about Vertere. I listened the PC and it was sweet on highs.
But knowing Göbel very well i think its energy will be very welcome.
Anyway, it is very surprising your change from Siltech TC to Göbel/Vertere.
Cheers !!!
Reactions: CKKeung
A +6db can help if the level output of your amp is too low. For me it was a little bit too much. Matej Isak of mono and stereo has one.
Reactions: CKKeung
Dear ckkeung, did it take a long Time to burn ni the preamp ?
Yes, particularly the silver transformer model.
About 2 months/200 hours at least for mine.
Ok thank you. What were the mainest improvement ?
Dear ckkeung, did you see my question ?
I was very busy at work yesterday.
What have you noticed when burning-in your Bespoke copper version?
For my silver version, the sound was transparent and finessee but s a bit "tight" initially.
The dyamics and soundstage opened up after burn-in.
Also, the midrange gained density, but of course won't be as rich as the copper version.
BTW my Bespoke are with diff connectors : Neutrik silver and Furutech gold & rhodium.
It took time to burn-in each of them and their internal connecting wires.
I have the same feeling. 200 hours will be at least needed.
Did you see the photo posted by Harry on FB ?
You mean the Bespoke with gold plated brass cowls(transformer enclosures) with a transparent Perspex lid ?
Yes, very beautiful.
Will you order the transparent lead too?
I had a TCV preamp for a number of years, and loved it! I only recently sold it and moved to a LDR "passive" preamp, which I also love. If your system can work well with it, and transparency to the signal is your goal as opposed to shaping the signal to your liking, I highly recommend a passive of the TVC or LDR variety.
I've not heard the Bespoke Audio preamps, but I imagine they are phenomenal.
Reactions: CKKeung
This is the Beapoke Silver Ultimate model ordered by my friend Paul in Hong Kong.
Harry said that this was the last one he would make, because the manufacturing cost was too high for him.
It is gorgeous to the extreme!!!
Beautiful preamp!
I think a decent resistor based volume control can equal a copper tvc but silver tvc is the best possible solution. The next preamp I build will use silver TVC + a tube buffered output.
Passive pres are a good option but they depend on the source having a robust output section.
Yes, I was about to say the exact same thing. I have build 3 passives, the last on using the Elna 48 step series attenuator with Takamn non magnetics. So only 2 resistors in the path. It worked well, but I believe active is better, more body and bigger soundstage. Passives are best at ultimate transparency IMO at some loss of timbre and realism, most other aspects are behind a good active stage. I have not heard the Bespoke.
On my work bench just now is the guts of a microzotl waiting for a hynes lps to arrive. I need to decide on the attenuator, either autoformer or LDR if anyone here has experience of comparing these two approaches?
There is no need for either one in an active preamp. Just use a quality resistor ladder attenuator, like Goldpoint.
This special version of Bespoke silver TVC has arrived at the hk dealer last week.
My friend Paul has not picked it up yet so I went for a brief audition yesterday.
Although not burned-in it gave a huge soundstage, much bigger than the demo Bespoke copper version at the dealer showroom.
Great potential!
I guess this may be due to the bigger TVC copper enclosure/cowl of this special version.
Reactions: WilsonDaDa
CK,
In fact i am also one of "the last several trains" before the price raiseup in Feb.;) Mine, arrived in mid March, must be the one before the Silver Ultimate version. I just have the basic copper version.
The soundstage becomes wide and deep. Both high and low ends extend more. The speed and transparency are very impressive indeed. Enjoy.
Reactions: CKKeung
