If I owned Lamm ML2 or ML.2.2 amplifiers what's a satisfying full range speaker under $50k and under $100k. (please, no subwoofers). Speaker should be available new with excellent manufacturer support. TIA
Doubt there are horns in your area to choose from with excellent manufacturer support. So you might have to stick to sensitive cones. If you ask Marc, it will be Zus. Those aside, you can try Stenheim Alumine 5. No idea if they work with Lamm but they are supposed to be 95 db easy to run. David used to match the Kharmas with Lamm before. Or you can try to bargain with Tang for his Cessaros
Oh you are not talking M2.2. Sorry.
Kind regards,
Tang
What is the approximate room size?
Tried and true, X2 S2
Oops, missed the new part! Sorry!
Lumen White Mystere.
I listened once. Superb sounding. I like them more than my YG Sonja. Here is a review of a smaller model.
http://highfidelity.pl/@main-771&lang=en
Tang
Have you heard or heard of Classic Audio Loudspeakers? (sometimes known as Classic Audio Reproduction CAR) Field coil driver. 16Ohm
They are in the state next to me. I don't much about them. They always show with Atma-Sphere.
http://classicaudioloudspeakers.com/cgi-bin/index.pl?fs=2&upper=25&content=26
Very interesting, Tang - thanks for that. I see the Ayon chap is involved.
5 Ohm, 90,5 db efficiency
I really like the look of this butterfly horns. What is the size of this thing approximately Ked.
Kind regards,
Tang
