I am not a vinyl guy at all. I just thought it would be fun to post so that there are now officially 5 owners of CJ GATs on this particular thread...Suteetat, Sunnyboy, Myles, XV-1, and LL21.
So far phonos I have looked into
Boulder 2008
Boulder 1008 ( a bit quieter and half the price)
Burmester 100 similar price to boulder
Allnic 3000
Ypsilon but requires separate step ups?
Accuphase c27
Audio Research Ref 2SE and Ref 10
Soulution 750 with power supply
Fm acoustics I have ruled out for compatibility issues as mentioned vide supra
And the Vitus Mp P201 and SP 102
Any others?
While you're at it, don't miss out the Gryphon Legato Legacy. I spent 3 days with one during a show in Malaysia, and I thought that it was one of the best I've ever heard.
Would probably consider that since I have gryphon pre & power except for the need to use Fischer connectors for all my Tonearms . That's makes experimenting with tonearm occasionally troublesome
Thx
Just looked at Thrax looks pretty beautifully made
Can you run different impedances simultaneously?
I see your in Melbourne
Whom do you get it from may I ask?
How did you get to demonstrate it first ?
Mikeafter spending the weekend with the new darTZeel pre-production NHB-18NS preamp with internal phono stage i'll have to venture my opinion that it is likely in the running for the very very best phono stage at any price. it is the best phono stage I have heard; although many of the other top ones I have heard are in show conditions.
not cheap. but when you consider it also includes what I think will be as good a line stage as there is too, it actually becomes quite a good value when compared to other very top level phono-line stage duos. and when mated with the dart 458's it is a formidable tour-de-force.
built like a swiss tank, battery powered, and excellent ease of use. it can be purchased with two separate phono stages in one chassis (which is how I have my current model dart pre). it offers up to 70 db of gain, and gain and loading can be changed dynamically on the fly thru toggles and LED's on the back of the unit.
Wot ... No RCA ?Sounds like the Dart kills two birds with one stone...great main pre and phono. If it wasn't for the zeel BNC connections (prefer XLR), I might even be a customer.
Wot ... No RCA ?
