Brinkmann Stand
Kcin
718
979
455
Canada
Do not want to clutter Ron's thread- but I had a couple of folks reach out- so here it is.
I used a similar HSS ( hollow structural steel) stand that was originally purposed for the Goldmund Reference- What happened to that very expensive heavy table is a mystery. However, I ended up with the stand and the top plate which is 2" thick brass it is massively heavy and inert. I layered a custom size segue mat on top for isolation and then with the HRS 3x . This HRS has the split top to isolate the motor from the table section. I do not believe HRS does this anymore. I added finite elemente ceraball feet for leveling and further isolation.
Lastly, I built a drawer for anlog junk as part of the stand.
When I had the Brinkmann Balance, I switched from a Finite Elemente to a bespoke Stacore rack with pneumatic Stacore platforms. The turntable resided on a Custom Advanced platform. The improvement was substantial as the turntable was fully isolated.
When I swapped to my current turntable which is much heavier, Stacore upgraded the plaform so it could sustain a heavier load.
Recently switched from Quadraspire to custom maple stand for Brinkmann Taurus. Found the Quadraspires a little less stable than I desired
Vinylfan,
Nice rack. Who's the manufacturer?
Purpose build. A good solid custom rack. Reasonably serviceable. My design and a good friend’s craftsmanship. Glued up Baltic birch layers and hardwood, with acoustic isolation footers. With an occasional side table for the RoNT II. Seems to support a nice quiet playback.
