garylkoh
Joe,
No problem. Send them to me for some long and exhaustive tests and I will provide you with the definitive answer.And perhaps the Aida's will love them!
As I have little hope that you are interested in this option, I can supply a simple receipt.
Play them using the GAT. Using a voltmeter in AC connect one probe to any ground in the system - even the outer part of a RCA plug of the GAT will do. Now while playing measure the voltage of the negative speaker connector and then that of the positive. They should be changing with the music. If one of them is zero or around zero you are using only half of the amplifier. If both change, no problem, it is working properly!
Good answer!
