Thank you Rocco. I am loving my 911 mono amps and like you recommend,plan to add a Burmester source at some point.
About the Y adapters, I never listened the 911's mono internally bridged by factory. For what I know, however the difference (if any) should be very-very small because the Y adapters are made with with same silver cable that Burmester uses internally in the 911's.
I wonder what it is about the design of Burmester gear that makes them so special? I see we have a mini-cult following happening here on WBF so this gear is obviously striking a chord.
(...) It is comforting to read that so many others who have compared (...)
Thanks Gary,
I am over the top happy with my mono 911mk3's. A friend on another forum recommended to use the "surround" pass through of my 077 to hook up my Conrad Johnson GAT preamp using the supplied RCA to XLR adapters. It works beautifully and sounds superb. I have the best of both worlds and can use either as the mood strikes. Awesome!
I ordered Steve McCormack's Interocitor to try directly between the GAT and 911's. I am curious if I hear any difference. I can return it if I like but I think I will have another use for it if it does not work out the way I want.
Joe.......Pardon me for saying so, but I think you're nuts putting an aftermarket box made by anyone between your 077 and the 911 Mk3 amplifiers. It seems to me you are digging a hole trying to climb the mountain. I know you like to experiment, so I will be watching this thread to see how the Interociter works out for you.
But Joe, how will you run your GAT with the 111??![]()
Just pulling your leg buddy![]()
I don't think that he is intending to use the Interocitor between the 077 and the 911. I think that he's going to put it between the GAT (a single-ended machine) and the 911 power amp. If the 1.8k ohm input impedance of the 911 is correct, the GAT has too high an output impedance for it. The Interocitor can also be specified as an impedance multiplier to improve the interface between the two.
Joe, did you contact Steve to make sure that you have the right version specified?
I have several years experience with Burmester 911 MK3, 069 w/ps, 808 MK5 w/ps, 089 and 948 conditioner. I can only speak for myself, but I (and not by a small margin) prefer the 911 MK3 with a hybrid tube CF-080LSX Linestage (using rca-xlr interconnects) and Great Northern Sound Company Statement Wadia S7i as source. An all Burmester electronics system to me veils the sound with a romantic "Burmester mist". Now to some, this is very desirable, but for me I like a little more detail and transparency. Is one system better than the other? No! We all know everyone has opinions. I base mine on 40 years in this hobby since grade school which has included Symphonic Line, Graaf, Chapter Audio, Conrad Johnson, Naim, Klimo, Marantz, Phase Linear and SAE.
Hi,
everyone has own taste to listen music based on his experience and culture for the music; It's the most important think. After listened for many years the Burmester gears mixed with a lot of components/speakers of other Hi-End brands the sound result was always amazing at all! But, I personally think that Burmester delivers the best and absolute performance when the system is "Full Burmester" including, especially, their outstanding and superb speakers. eg. B100's,B80's, B50's, 961 MK3, B30's. At that stage and at my ears Burmester provides an exhilarating musical experience very close whilst listening to a live performance.
I invite you to listen the same Burmester components with their top awesome speaker like the B100's or B80's; so you could re-consider the concept of transparency followed-up by an highest degree of pure musicality that Burmester owns.
Hi,
