You don't know what you are missing, Joseph!
I know, I know......but right now I have to practise delayed gratification![]()
---He's an European man! :b
And there is a lot of info with pictures avail online, behind the man and Burmester the company.
...It is indeed very unique; the entire design process.
...And all with one goal in mind: Purity of the Audio signal.
Burmester must be filling his gear with audio crack because he seems to addict his users. Seriously, I do wish we had some more insight to how he is designing his circuits to understand what he is doing different than others.
I don't think there's anything different... They're superbly designed and sounding components, as well as other from many other audio brands all over the world.
Personally, I have auditioned Burmester systems with components from the top and reference lines and I found them outstanding.
Instead, I have not been impressed by lower level components, such as their integrated amplifiers and the compact speakers (notwithstanding, you'll always find on the web some fans writing that Burmester is the best in every category: I personally do not agree).
Unfortunately, here in the US the top and reference lines are way more expensive than in Europe (~ twice)
... Unfortunately, here in the US the top and reference lines are way more expensive than in Europe (~ twice)
Ciao Valerio.
<snip> ...
P.S.: I don't know which Burmester line you're referring to, but in the entry line levels, Burmester builds at my ears also high-end components that sonically are superb. I've a lot friends that own them and after a lot of true comparison A/B with similar products of the same league or more of others high quality audio brands, Burmester has always demonstrated better musicality at all.
I still would love to get an answer to my question about the 2kohm balanced 22kohm unbalanced input impedance of the 911mk3 or mk2 - even our local distributor could not answer it!
Ciao Valerio.
I think I should know you!!
Micro, I have stated this before in this thread (maybe you missed it) - I called Burmester and spoke to a technical engineer. The impedances are as you state.
Also, Jeff Dorgay (Tonepub) runs 6 meters of balanced (XLR) cables from his ARC REF5SE to his 911mk3 and he says they work great together. I'm pretty sure if there was a compatibility issue, if anyone would hear it it would be him.
AudioExplorations,
Thanks, I have not missed it, but I believe in the laws of electronics and this is not possible, unless there is something we do not know about in these XLR-SE adapters.
A 2Kohm balanced line can not be converted in a 20kohm single ended just by shorting one input.
And the Ref 5E can not drive a 2kohm balanced load properly - there are technical limitations that would result in low bass filtering and rise in distortion.
Burmester can be great sounding, but I do not expect it to be technically miraculous!
Most likely the technical engineer just pulled up the owner's manual or spec sheet with the typo and regurgitated the figure. I dare say that a lot of the technical specs in the Burmester documentation is just plain wrong..... like the 909 being a 100W amp until a few weeks ago.
---Makes total sense to me what Gary just said above regarding typos.
* For definitive confirmation, simply contact Burmester's official office from their headquarters.
...Or their website, and ask. :b
AudioExplorations,
garylkoh said:Most likely the technical engineer just pulled up the owner's manual or spec sheet with the typo and regurgitated the figure. I dare say that a lot of the technical specs in the Burmester documentation is just plain wrong..... like the 909 being a 100W amp until a few weeks ago.
