For the record, and IMO, considering just RLCG can indicate why some cables sound different in some systems. I am not saying that is all we should measure or consider, but
sometimes it
is enough.
I have measured the variation in capacitance with d.c. bias and it is very small for most cables; I would certainly expect it to be inaudible.
Filling the charge traps/voids, well, I can in no way see how that would be enough to change the the "sound" of a speaker cable given the impedances and signal levels involved, and it seems unlikely to significantly (i.e. audibly) reduce the noise floor even of an interconnect, but I have not run the numbers nor made any measurements to support that. The data I collected (for an RF/mW test system, several years ago), the effects were in the uV region. Enough to matter in a 100+ dB RF front end, but would be less notable in an audio system, I would think. The catch that holds me back is that charge traps lead to things like flicker noise that affects lower frequencies more than higher, thus even though the measured data is tiny, it would be more observable at audio than RF frequencies. In my case, it affected the close-in phase noise around the carrier.
One interesting side note (perhaps): a long time ago in a galaxy * -- oops, it was this galaxy!
-- I played around with biasing cables and found a significant (few dB) lowering in noise and distortion, but only with a certain preamp. The cable mattered little in that case, but the effect seemed only significant with that preamp. Turns out I was biasing the balanced output stage, shifting the bias across the coupling capacitors. The capacitors were a grouping of a big electrolytic and smaller films; it can be shown that biasing an electrolytic cap can improve (or not) its performance.
One of many little experiments that lead to insight about the reason why, even if not what we expect, and a caution to not dismiss our ears out of hand. Nor to dismiss the techies' reasoning and ability to find the cause (alright, I am biased on that last...
