Cable between SUT and phonostage
Kinn
20
20
68
Hi, in question is, will you use a regular interconnect between SUT and phonostage or will you use the same phono cable like the one meant for your tonearm?
I have always use tonearm with captive phono cable but had recently bought a tonearm that needs a phono cable. Hence, wonder if I plan to match my phono cable with the cable between SUT and phonostage, should I be buying an interconnect cable or a phono cable with RCA termination?
Best wishes
hogen
139
101
148
Oslo, Norway
My experience is that a dedicated phono cable is much better here than a normal interconnect cable.
Reactions: mtemur
Dogberry
Active Member
Aug 24, 2022
134
93
35
65
I went out and found some one foot long interconnects to go between SUT, phono stage and pre-amp, rather than 3ft/1m ones. It really does make a difference, of the order of changing from one cartridge to another.
