You must do some mods on this board e.g voltage ref then it will be even better. The noise level is then at the measurement limit. this generates more dynamic and a wider deeper soundstage. Mod site
The r ladder output is 1.4Volt zout 625 ohm i have test it with transformer coupled, with normal tubes and dht.![]()
Soekris DAC: Modding VRef
MUST DO MOD? As it turned out, the implementation of the 4V reference voltage in the Soekris DAC has been found to be sub-optimal. Fortunately, thanks to experiments and measurements by industrious…hifiduino.wordpress.com
So many use that board lampizator, accuhorn ,lessloss and many more.
In the end i use Nos and this buffer ..wow that dynamic and cleaness is insane.
https://www.sjostromaudio.com/pages...joestroem-super-buffer-diamond-buffer?start=7
My dacView attachment 126505
Congrats ,I think the dac have the new oem board 1121 not dam 1021soekris.Very nice.
Here is my Acuhorn, seeing as you mention them. Using a Soekris DAM1121-001 board.
Stunning and totally analog-sounding. Running 45 mesh globes. Internals rewired to Mundorf silver and gold wire.
This amount of good, but scarce chips in just 1 device makes me involuntarily think:
The task was to keep the noise floor lower in order to keep the resolution as high as possible at low levels. Of course, two chips per channel also drive the transformer that drives the tube. but if there is a no supply shortage why notThis amount of good, but scarce chips in just 1 device makes me involuntarily think:
"With those precious AD chips multiple DACs could have been made, each with 80-90% of the (sound) quality".
VMS is wanted in Germany and you can sell it expensively. The irony of the story 20 years ago no one wanted to buy LPs . They sold everything to Japan only to buy them back at twice the price today.In light of this thread...
"Optimizing Morpheus DAC for use in conjunction with Neumann VMS80 (lacquer) and VMS82 (DMM)":
View attachment 126763View attachment 126764
If you are interested in all these aspects, you should check out ECDesigns' powerDAC-SX, which from a "technical" perspective is something really different and "novel". I've talked enough here about my own listening impressions. I know only of two other people who have this product. One is a dealer, who decided to commercialize it after listening to it. The other is an audiophile who uses Wolf Von Longa Son speakers, and basically replaced his whole setup (DAC + amplifiers + preamps) with the powerDAC. But YMMV, obviously. I don't really fully understand all the technical aspects. From a listener's perspective, it sounds "right" to me, but speaker association becomes critical, and here the distortions introduced (crossovers, speakers, room) are potentially of a much higher order. I think it's good to keep that in mind.In terms of purity of the signal, there's no alternative to analog (+ Class A).
However, analog signals are more sensitive to noise and distortion. In addition, energy efficiency and convenience (storage) also play a role.
It's a schism: analog data represents a continuous function of time while a digital signal transmits data in a discrete function of time.
"Analog waves are smooth and continuous, digital waves are stepping, square, and discrete."
Earlier I wanted to ask how you like that DACIf you are interested in all these aspects, you should check out ECDesigns' powerDAC-SX, which from a "technical" perspective is something really different and "novel". I've talked enough here about my own listening impressions. I know only of two other people who have this product. One is a dealer, who decided to commercialize it after listening to it. The other is an audiophile who uses Wolf Von Longa Son speakers, and basically replaced his whole setup (DAC + amplifiers + preamps) with the powerDAC. But YMMV, obviously. I don't really fully understand all the technical aspects. From a listener's perspective, it sounds "right" to me, but speaker association becomes critical, and here the distortions introduced (crossovers, speakers, room) are potentially of a much higher order. I think it's good to keep that in mind.
Anyway, I think you'll agree that analog is continuous and digital is 'chopped'.Standard misunderstanding of digital theory. There are no "discrete steps":
It's explained in the first 9 minutes of the video, with irrefutable evidence from an oscilloscope. It is worth watching the entire video, however, since it debunks other things as well, such as "filtering artifacts".
Reminds of an explanation of dark matter > "it's not dark and it doesn't matter".I remember faculty meetings at Vanderbilt where two unwilling groups had been grafted into one department.
The few actually apolitical participants were frustrated rather than invigorated by the constant bickering.
I remember one conversational string that began “There is no such thing as a dead issue here.” This led to the epiphany that “There are no real issues here.” The whole odiferous mess was about power and who was superior. Neither side wanted to be the tail, but the end result was two tails … both trying to wag the dog.
I like mind over matter … “If you don’t mind, it doesn’t matter.”Reminds of an explanation of dark matter > "it isn't dark and it doesn't matter".
The basic principle: The red digital signal is the sampled and quantized representation of the gray analog signal. A digital signal consists of a sequence of samples, which in this case are integers: 4, 5, 4, 3, 4, 6...
The confusion/misconception probably lies herein:
"The process of analog-to-digital conversion produces a digital signal.
The conversion process can be thought of as occurring in two steps:
- sampling, which produces a continuous-valued discrete-time signal, and
- quantization, which replaces each sample value with an approximation selected from a given discrete set (for example, by truncating or rounding)."
Interestingly: "The human brain cannot accurately be described as either analog or digital, but contains elements of both".
