Don’t know about you, but I can post AND listen to one of my systems at the same time…
No, I never go on my computer when I am listening to music.
I don't watch much TV and I try to limit my computer time.
Do you also have a strickt bedtime ?No, I never go on my computer when I am listening to music.
Do you also have a strickt bedtime ?![]()
No, i already know you limit your computer time !Do you want to know my sex life?
If you take a competent ADC such as the Merging Horus, and monitor the mic feed directly and after A/D-D/A, there is really no difference, at least with DSD128 or above. I can hear some telltale signs if it is done with PCM, even with 24/192. I describe it as adding a sheen to the sound, as if there is a brightness, even though the frequency response has not changed. Recording the signal on hard disc (SSD) and then retrieving it does cause degradation because of jitter, noise and other issues.i can fully enjoy my right brain digital listening, my left brain knowing it's not as real as the best analog, but not being reminded of it by what i'm hearing. it's good enough and then some. zero of the digital signature concept from years ago.
certainly i don't view any source or media the same as a real performance.
but at digital's best it does a very good job of degrees toward realism. and again at it's best also does not add nasties distracting from the music. however analog is more complete, and closer to the realism of a real performance. and analog also is more likely to be preferrable overall to some live performances, while never being the same.
digital offers by degrees less micro dynamics, less organic weight, less bloom in the soundstage, less nuance. but at it's best it also does do all these things admirably. the best digital fully satisfies me, and does not make me think of what it might be, it is the real deal for enjoyment. and mostly i listen to digital, even with lots of quality analog to choose from.
but it does not end up in the realm of good all analog vinyl. why that is i cannot say. whatever might be heard in the control room is not there with the end files. dsd/dsd128/dsd256/dsd512 files or sourced vinyl all fall short of full analog sourced vinyl. just stuff missing. but it's very very good no doubt. good enough even. but.....not the same as good vinyl. in my experience.If you take a competent ADC such as the Merging Horus, and monitor the mic feed directly and after A/D-D/A, there is really no difference, at least with DSD128 or above. I can hear some telltale signs if it is done with PCM, even with 24/192.
No, i already know you limit your computer time !![]()
I think it is important to expose most digital recordings for what they are (to me and many others) absolute garbage. Why do you think this thread exists? Many are dissatisfied!
WBF should be at the forefront of demanding change to improve digital recording so that threads like this become redundant.
Let's take your example of the North Dakota track, by Lyle Lovett, which you, rightly IMO, described as kinda dry and typically digital. The words I would use is absolute garbage. It's kinda like you can't be a little bit pregnant. Things sound real or they don't."Absolute garbage" appears to be another ridiculous exaggeration. Your personal opinion aside, please provide us with some objective evidence that "many others" agree with your assertion.
That's a very good analogy, actually.described as kinda dry and typically digital. The words I would use is absolute garbage. It's kinda like you can't be a little bit pregnant.
I don't think the recording is this bad...perhaps your digital is exacerbating these issues?Let's take your example of the North Dakota track, by Lyle Lovett, which you, rightly IMO, described as kinda dry and typically digital. The words I would use is absolute garbage. It's kinda like you can't be a little bit pregnant. Things sound real or they don't.
I'm listening on Tidal so there might a better version but Ron said his vinyl copy sounded like the Qobuz version so I doubt it.I don't think the recording is this bad...perhaps your digital is exacerbating these issues?
However, it is a reason why I think most audio electronics suck. Most have way too many electronic artifacts like dryness, synthetic quality to tone and timbre etc.
Lack of artifice is rare as hen's teeth.
Only heard it on cd...I'm listening on Tidal so there might a better version but Ron said his vinyl copy sounded like the Qobuz version so I doubt it.
Usually it is one person's vision of how things should sound. Some have a good idea what it should sound like an some don't and some just design by numbers.Is it poor design or are these distinctions intentional and how the designers differentiate their products from the rest, claiming musicality or neutrality, while all sounding different to try to attract their customer?
I totally agree and with the work I have done with products to eliminate noise the digital sounds much better. The assumptions that digital is digital and its all kind of the same is profoundly false. Even within the best digital products there are many ways to improve the overall sound. These findings have happened becasue of the technology not inspite of it.I find the better your system and room set up are the better digital sounds. You can hear this because of the quietness of digital. It’s understood that you are starting with a great digital system as well. Analog always sounds good but you will hear the improvements as well in better imaging and spatial cues.
disagree. there is a big difference between "indifference to digital for any of a hundred reasons", and being "dissatisfied" with digital after actually investing in trying to find enjoyable digital. and mostly i think that those who are indifferent to digital involves more that they like the analog media they have and are not motivated to explore what digital has to offer.I think it is important to expose most digital recordings for what they are (to me and many others) absolute garbage. Why do you think this thread exists? Many are dissatisfied
there is ample evidence that WBF is all in pushing digital boundaries (within current tech) if you open your eyes.WBF should be at the forefront of demanding change to improve digital recording so that threads like this become redundant.
I may be late to this however may I know what your digital and system is?I'm listening on Tidal so there might a better version but Ron said his vinyl copy sounded like the Qobuz version so I doubt it.
