cartridge that minimzes clicks/pops/surface noise
magical_mouse
1
76
Hi, i have a nagaoka mp200 and denon dl110, the mp200 tends to accentuate noise/pops etc. and also seems to attract static but is otherwise a very musical cartridge
Are there any other cartridges which are especially good with this issue, i do not want to spend more than (say) £400. I have been recommended the audio-technica VM95SH but i have read it is bright?
Any ideas would be welcome
d
Increasing noise and clicks may be related with cartridge’s static behavior but also may be due to worn out stylus. A worn out stylus known for bottoming in the groove and increasing noise.
I recommend you to try AT-VM95C if you find the shibata tip version bright. It’s a very cheap cartridge but punches above it’s weight.
Mp200 has 0.4 × 0.7mil Ellipse diamond. It's not tiny one so should cope with clics/pops quite the same as Denon DL110. Maybe not as good but close to it. Do you clean diamond of the stylus from time to time?
I’ve not used an MM cartridge with a fine line stylus but of the MC I have those with Replicant 100 and Gyger S styli seem to make much less of clicks and pops than the micro ridge and Ogura PA styli which have a smaller major radius. The Goldring 1042 is the only MM I know of to carry the Gyger S profile but I suspect it will be over bedget and I’ve not actually used one.
