I used the same acoustician. She places a lot in the RT 60 test
The ceiling is just drywall over some wood framing to support the floor above.
Thank you, gentlemen!
Jack -- if the speakers are 7' tall, my ceiling would be 1 1/2' above one speaker and 7' above the other speaker.
Can I ask what specific "numbers" we need in this case? And any way we will need beliefs when analyzing any numbers in small/medium sized rooms.
Ron,
There is only one solution that makes any sense. The hell with the floor above! You always wanted a cathedral ceiling your listening room anyway, right?
Marty
In a listening room if the ceiling above one speaker is lower than the ceiling above the other speaker, should the lower ceiling be treated with diffusive acoustic material or absorptive acoustic material?
Does your answer to this question change if the audiophile is using dipole panel speakers versus dynamic driver box speakers?
I'm with Marty on this, screw the garage! That's a big height difference Ron, its hard to make any recommendation without seeing proper pictures of your room but you already know what that ceiling is doing after all these years, not going to change.
david
how much difference are we talking about , mm , cm ,..meters ???
I appreciate the suggestions of each of you, but is there really no consensus as to whether absorption or diffusion more successfully makes a section of wall or a section of ceiling "disappear" acoustically -- as though such section of wall or ceiling were literally not there?
Absorption is the right solution to asymmetry. It would have to be broadband which means at least 4 to 5 inches thick.I appreciate the suggestions of each of you, but is there really no consensus as to whether absorption or diffusion more successfully makes a section of wall or a section of ceiling "disappear" acoustically -- as though such section of wall or ceiling were literally not there?
The ears are the right tool to analyze acoustics above a few hundred hertz.
Who are are you and what have you done with Amir?
