My room has a half angled ceiling on the left, (see system pic http://www.whatsbestforum.com/album.php?albumid=68&attachmentid=5391), and the REW frequency response from the left and right sides are almost identical. The left side has a narrow slight dip at 40 Hz and the right side has a narrow slight dip at 45 Hz and the right side has a narrow 2 dB dip at 300 Hz that is not present on the left. All in all, the system is very flat from 10Hz to 20kHz and I can't say that specifically the ceiling is making as much of a difference between channels compared to the left wall being glass and the right wall being one inch thick hard pine over sheetrock. Still, both sides have a very similar room frequency response and it sounds very musical.
Acting like planar/line arrays they should not radiate much to top/bottom so that makes sense (not being very sensitive to the ceiling). OTOH, I think it makes sense to subject them to more rigorous independent evaluation, something I really don't have time for with my work schedule but am willing to do just for you, so ship them to me and I'll let you know when I'm done.![]()
Hi Ron
I have a very similar situation like you are facing in my second listening room.
My room is asymmetrical as well and I also have rather tall electrostats where the left speaker almost touches the cover of a beam above. Because of the radiation pattern of dipoles/line sources that almos no sound goes to the floor or the ceiling, this isn't as bad as one would think.
When I set up the speakers in that room, I wasn't expecting good sound at all, but I was proven otherwise.
You can ask Kedar/bonzo what he thinks of that system/room.
Have you considered to "open" up the hard cover over the beam and piping and add damping around the beam and piping and then cover it again, but with sound transparant fabric, so that it looks covered and clean, but is sonically tranparent? I'm pretty confident that this would improve your situation sonically, while keeping the clean and tidy look.
Cheers,
Christoph
Here:
If you have a set of crates made and pay for shipping both ways I'll do that for you while I'm on vacation!![]()
